abog
About abog
- Birthday 01/15/1960
Contact Methods
Yahoo
coneassassin
Location
reno
Interests
autocross, radio control cars
Occupation
automotive
Biography
senior master subaru tech, 1982 through 1999
Vehicles
1988 RX, 1997 outback
abog's Achievements
USMB is life! (4/11)
0
There it is, thanks
Hey does anyone know what happened to GD's swap write up? The link doesnt seem to work....
Head Removed Without Removing Motor On 84GL?
abog replied to roadsubiedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If its a 1984 as he said, it is an ea81 -
Finally had some time today to work on the hatch, Pulled the engine and began disassembling. So far nothing horrible, I am thinking that the compression rings are stuck on the low cylinder. Am going to totally disassemble for a good cleaning, new gaskets and seals. I am hoping that all I will need to do is hone the cylinders and install new rings, but I haven't measured anything yet
The best part is everything comes apart without having to use a torch.... I am originally from the northeast and am all to familiar with rust, and I have to say it is nice not having to deal with it .
Yes it is in pretty good shape, drivers front fender has some rust on the bottom and a little in the drivers rear wheel well. Both look like easy repairs. Next step is going to be diagnosing the engine trouble and choosing which way to go with it.
Picked up a new project a 1988 hatch back. Solid Nevada car, in decent shape. Has no compression in the number one cylinder. Have all components for an EJ swap as well as an EJT upgrade, decisions, decisions.....
The light harness is called a headlight fuse kit. It just plugged in between the original harness connectors. GD is correct that your lights should work fine if you just took it out. I am trying to remember where the other end plugged in but it was a long time ago........sucks getting older. The original headlamp fuse holder was secured by a rivet that held it to the terminal plate, this rivet could loosen and the higher resistance of the circuit would cause the solder to melt on the fuse resulting in headlamp failure.
Engine knock
abog replied to mikec03's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you were to pull the heads and remove the valves, you would be amazed at the amount of carbon buildup that is on the valves. -
Definitely not a good idea to use a torch on a/c components. Most of these parts are aluminum and can easily be damaged. Nipper is correct on his warning, never fool with the high pressure side with the small cans. If the system is not running you should be ok, but it is a bad habit to get into. All it would take is one mistake and you could be seriously hurt.
