About 91 subaru
- Birthday 06/05/1982
Gender
Not Telling
Location
miami, ok
Interests
fishing and subarus
Vehicles
81 hatch
91 subaru's Achievements
Eat, Live, Breath Subaru (5/11)
6
help with timing problem
91 subaru replied to 91 subaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sure is. Thanks for the help fellas. By the way, i am going to sell this car once its running good. -
No timing belts in this car. But you were right. Timing was off just enough to make it not run. Its running now. Sounds sick but it is running -
I almost would -
Pulled the top off the carb. Unscrewed tubes and blew air back through them. Also the bowl has fuel in it. No change as far as running. Anyone wanna buy this headache :-) -
Ill pull the top and blow air in the tubes. -
Carb taken off, taken apart, cleaned out soaked and put back together with new gaskets. -
Already blown out tubes. -
Ok. Tested fuel pump. There is 11.56 volts while cranking. I poured a little fuel into the carb and it tried to run. Is it possible for the fuel pump to be weak? -
Just quit running. No noise or shutter or anything. Just like i tirned the key off. Went from driving to dead... -
Well i have had the carb rebuilt, new head gaskets, new intake gaskets, valve cover gaskets, plugs and wires, cap rotor, coil, ignition pick up, adjusted valves, new fuel filter, new air filter. Adjusted timing. The car ran good. After all of that i decided to go for a drive. I drove the car all day let it sit for a couple hours then drove about three blocks and the car died and now will not start. Anyone have any ideas on where to go next? -
I only see one adjusting screw on the piece of crap hitachi. I have rolled the motor over a zillion times. The timing is set at 8* btdc, rotor pointing directly at #1 on the cap. I try and start the car it will run super rough for about 5 seconds revs to about 800 rpm, puffs black smoke out of the carb then dies. Anyone have any ideas? -
81 hatch dl Im having trouble getting the timing right. I have pulled number one plug and confirmed tdc with the drinking straw and looking in the cylinder with a light.The timing marks line up on zero. I back the flywheel to 8* btdc and set the dizzy to point at the number one plug wire. When i start the car it runs really rough for a few seconds then dies. Its idling at 600 rpm. I can run the idle screw all the way in or all the way and anywhere in between and it makes no difference on the rpm. What the heck am i missing?
correct me if im wrong....
91 subaru replied to subi dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have also heard it lubricates the water pump internals. -
2" or 4" Lift - I need your input!
91 subaru replied to nkmilesAE95's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Two inch is what you want. easy to build yourself and easy to install. i had a 91 loyale with a 2 inch lift and 235/75/15 tires. lots of hammer smashing and a little bit of cutting and it was great -
Purple lightning under the hood?
91 subaru replied to thebr0wn0ne's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I hope thebr0wn0ne is gettin all this. i feel like i hijacked the thread
