jackbombay
Location
Idaho
Vehicles
I Love My Subaru
jackbombay's Achievements
Member (2/11)
0
91 loyale crank angle sensor
jackbombay replied to jackbombay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmm, so open up the dizzy and look for anything blatantly wrong? -
So I have a couple fault codes, 11 and 13, which are no referance pulse and no position pulse, the car still runs ok though. From reading around it seems like those codes are usually accompanied by poor running. Can the crank angle sensor go bad enough to throw a code, but not bad enough to notably affect how well the engine runs? The Check Engine light came on a few days ago so I have not filled up since it came on to know how the MPGs are.
Busted a CV joint, 4wd saved the day!
jackbombay replied to scrounge's topic in Old Gen.: 80's GL/DL/XT/Loyales...
DOJ= Double Offset Joint DOJs drive the rear wheels. -
What are the best front brake discs?
Normally I can't see where an loyale would ever have rotor warping issues, but this pass really is brutal, 3 miles of %10 grade on both sides. I'll start with making sure the rears are working well along with new brembo rotors. New cylinders for the back should be pretty cheap so I'll swap them out while I'm in there along with a full bleed/flush. -
http://www.car-part.com is an online catalog of junk yards and you can find just about anything there, I'm not yet sure which bits and pieces you need for the rear disc swap, but I'd be surprised if you couldn't find them at car-part.com -
That must be why the rear pads last so long I'll look into the rear disc swap, a search certainly brings up plenty of threads on the topic! Is it illegal if the chute blocks the tail lights? I'll go with some brembos. -
The brakes are in good shape with the exception of the warped rotors, they were turned a few months back and they warped again pretty soon, which I was pretty much expecting. I've never been a fan of turning because of the resulting variable metal thickness, but it was cheap. Yea, its a 90 HP economy car, but the pass in question ruins car for a living. With a full tank of gas and a few people in the car 2nd gear will redline downhill if you don't use the brakes, and there is 3 miles of hill on both sides of the pass. I realize that theres no chance that nobody else here is in the same situation, but though maybe some of the turbo guys had tried the slotted rotors, or was hoping to find out if people typically have good luck with the brembos, which is what I'll probably go with at this point... -
You talk s#!t about my driving based on, my post count? And I'm supposed to be grateful for your s#!t talking because why? -
Cute, especially coming from a flatlander. -
I did search for "front AND disc" and "front AND rotor" and did not find that, but it doesn't look like he ended up selling them. I don't necessarily want slotted unless it prevents warping better. I'm not sure what is on the car now, but probably not brembos. Have you guys typically had god luck with brembos? -
jackbombay posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I found Brembo rotors at tire rack for $74, http://www.tirerack.com/brakes/results.jsp?autoMake=Subaru&autoModel=Loyale&autoYear=1991&autoModClar=4wd and I found some drilled slotted rotors for $99 with a lifetime warranty, I assume that covers warping, http://stores.brakeplanet.com/Items/nl037773?&caSKU=nl037773&caTitle=91-94%20SUBARU%20LOYALE%20F%20Slotted%20%26%20Drilled%20Brake%20Rotors I live near a HUGE, STEEP pass that has a habit of warping rotors. Does anyone have experience with slotted/grooved/drilled rotors? Were they more resistant to warping? I've had good luck with ATE power rotors in the past, but they are not made for my 91 loyale :-/ Thoughts? -
91' loyale, low MPG, intermittent CEL
Replacement throttle body is in. Car runs smoother, and notably more power at low RPM and or low throttle settings, also it had an odd hesitation before that is gone. I also cleaned the MAF off with brake cleaner. And I cleared the codes, I'll check in a few days to see if either/both of them come back. Thanks for the help guys! -
When to retension timing belt?
jackbombay replied to MR_Loyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The retension was free... -
I had a T-belt skip when it was 18k miles old, it had not been retensioned at 10k as is recommended. The local subaru mechanic retensions them at 10k, fwiw he's be wrenching on subarus for 25+ years now.
