bikeweek
Everything posted by bikeweek
  1. So is it safe to say when I locate the B82 connector ground terminal 5
  2. IMG]http://i600.photobucket.com/albums/tt88/bikeweek_01/Picture134.jpg[/img]
  3. I located the B82 connector and the two ground wires looking at the B82 connector terminals 4@5 their is no wires going to those two terminals in the connector I will take a picture of it and post it
  4. Ok I found the two wires under the dash removed the tape from them and grounded one of them and turned on IG and no blink from the trans light Grounded both of them and no blink what am I missing
  5. I have a 99 2.5 OBW 1000 K trans light flashing after 20 min highway run if you shut off the car off and re start the light goes out ( so that tells me the trans is not hot because light would light back up if trans was overheating ) checked with my snap on scaner and find no codes I found out that if on ice I get no rear assist what shuld be my next course of action ohm out trans sol and switches please give me some input
  6. -------------------------------------------------------------------------------- I have a 99 OBW 2.5 100K my trans light just started to blink I found that on snow I have no out put from the rear wheels fronts are doing all the work if I shut the key and re start car light goes out so I know that the trans is not hot If I street drive the car the trans light will not light up the light will only start to blink if I go on the highway so I it maybe the converter lockup I am ok with opening the tail shaft and rebuilding the transfer clutch replace duty C sol what would you do
  7. I have a 99 OBW 2.5 100K my trans light just started to blink I found that on snow I have no out put from the rear wheels fronts are doing all the work if I shut the key and re start car light goes out so I know that the trans is not hot If I street drive the car the trans light will not light up the light will only start to blink if I go on the highway so I it maybe the converter lockup I am ok with opening the tail shaft and rebuilding the transfer clutch replace duty C sol what would you do
