FPOYA
  • Vehicles
    I Love My Subaru
FPOYA's Achievements
Newbie
Newbie (1/11)
0
  1. thanks i resealed the oil pump and have put over 100 miles on it and its still loud . it dose seam the the pass( right ) side is louder. hard to tell with all that noise. i may have used the regular o rings. the gaskets are oem with what ever they came with. although im not sure if i didnt get the rockers mixed up, right to left, left to right . thanks
  2. thanks ill go look at the filter and the lines when i was under it the atf oil is comming off the cross member and by following the clean trail it appears to be comming from between the motor and trans thanks frank
  3. my daughter has a loyale with the 1800 motor nonturbo i replaced the head gaskets and now when it runs there is VERY LOUD valve train noise.VERY LOUD help and thanks
  4. i have a 99 obw 2.5 auto wich has an atf leak that is comming from the back of motor/front of trans. from reading it sounds like trans seal, havent worked on trans much how big of a pain is this in time and $ thanks,frank
