About eppoh
- Birthday 10/27/1955
Contact Methods
Website URL
http://www.campaignforliberty.com/
Location
So central Texas
Vehicles
97 L, 00 O/B, 66 Bellanca
eppoh's Achievements
Subaru Fanatic! (6/11)
Well I installed that compressor with both brackets, but just the one bolt on the bracket 17 would not line up. Like I said, though, with it installed that way, it was out of alignment. So what you say, makes sense, that the # 16 would be the culprit. I wish there was a diagram that showed all the washers and any spacers. Maybe I just installed it wrong. Can you see on yours washers or spacers that would affect the alignment of the other bracket?
After getting the engine back together in the 97 2.2, the AC bracket will not line up with all the mounting holes in the block. One of them is about a 1/4 inch off. Someone who I had hired and then fired to do an engine swap had brought an engine from a 93. I am wondering if he got the wrong bracket. Anyone know if the AC mount bracket for a 93 is different than the 97? Otherwise, I must have put it together wrong with the alternator bracket. With the compressor installed the bolt on the tip ( right side) of the bracket doesn't line up and the compressor is out of alignment with the crank pulley The bracket I am referring to is number 17 in the diagram
My experiences with oil leaks on the EJ engines are #1 the cam seals ( yes that is in the timing belt area) #2 oil baffle plate, #3, head gaskets. Baffle plate and head gaskets are not worth messing with unless you are the type to loose sleep over a dirty garage floor or a little whiff of burnt oil. Engine pull. The cam gaskets get done at timing belt change. I put down a big piece of cardboard box in the garage and live with it. Also, if you are smelling burnt oil, check the right front outer CV joint boot,. They tear and throw grease on the exhaust
With these cars getting to the 15 year old stage, they get traded by used car dealers. Often they will slap a new T-belt on them so they can say "oh yeah, new timing belt" The average buyer does not understand the problem with not changing water pump or idlers, and a year later, wham! When I was looking for used wagon for my son, I checked out several small dealers cars. They would universally say, yeah we changed the timing belt. When I asked about idlers or water pump, I would get a blank stare and then they would say, "no they were fine".
There is a kit you can rent at Autozone, that tests the coolant for combustion gases. It is easy and cheap ( free) There is a little bulb sucker with a resevoir that you put a little chemical in. Then you position it on top of the radiator with the cap removed and suck a little air from the radiator into the tester. The chemical in the tester will turn a color if there is combustion gases present. I used on on my OB before I bought it.
To make a long story short. Someone pulled the engine to swap it, since this one had bent valves. The engine he brought was no good, so removed the heads to have them repaired. He quit, and left - everything laying around the shop. My son ( it's his car) decided to remove the intake and paint it red. That is when the tube was removed.
