Everything posted by subyrally
86 wagon gl balljoint replacement questions
subyrally replied to hyrysc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i use both actually, but as far as the rust breaking part, i really havent used deep creek much for that yet, lol. i guess ive been using blaster too long to want to try other stuffs for breaking rusted bolts loose. -
i dont have much advice other than use pb blaster instead of wd-40, wd-40 is water compaired to pb blaster -
Hawk makes pads for ea81 cars
subyrally replied to Jerry DeMoss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
shhhh! if i keep telling myself, one day ill believe it:lol: . but seriously, i do drive a lot better than the rest of the people in the dc metro area, sadly enough. i love it cause driving the speed limit angers a vast majority of the other people on the road around here. i love angering stupid people, its funny to watch their faces cause im not driving like a retard. -
i took the backing plate out on my impreza long ago. granted, mine is a 2000 impreza, so i dont have a maf. thats why i am able to run my air filter right off of the throttle body under the hood scoop. the only time ive ever had any problems was when i was at highway speeds directly behind a semi truck in rain so hard that i could barely see past my hood. then all i got was a check engine light saying that my cats werent working as well as they should.
i honestly prefer closed courses as well, but unfortunatly, thats not very easily accomplish for me, granted, summit point is only about 35 minutes away, but that requires a lot more money that i have to spend. i might drive spiritedly in the hills, but i keep the car in control and dont get to excessive speeds, and i always slow down when ever there are other cars on the road. one of the main reason is really only drive the hills at night, you can see the other cars on the road a lot farther away from the lights. the real trick is avoiding deer though. granted, they dont like the sounds of a quick rev in nuetral, especially with a turboed car with a bov. im not trying to sounds like some type of ricer that drives like an idiot, i dont street race, i drive at the speed limits, i just happen to love the twisties but i always keep the car under control and drive within reason. i like to have fun, what can i say. -
subyrally's annual frederick cookout!!!
subyrally replied to subyrally's topic in Meet n' Greet. Your USMB Welcome Center
needs more cowbell http://dontfearthecowbell.ytmnd.com/ and yeah, lets do this and have some fun this year. -
Try this before dumping your air suspension!
subyrally replied to KRMusher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmmm, cool deal man. glad to hear that someone had some success in getting that stuff working again. -
I FINALLY got my car's air conditioning fixed!
subyrally replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
dont worry, i dont like a/c that much to begin with, and i wouldnt ruin my brat like that. -
shhhh!!!! -
why does that give me bad ideas? -
EA82 rpms shoot up until it's warm
subyrally replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
dont know about the spfi engines, but i know that the ea82t's that i have came with both, the iac is on the back side of the throttle and the aav is ontop of the thermostat. i ran into a problem with that when i mounted the xt6 throttle body onto a regular xt manifold. the xt6 throttle didnt have the iac valve and the car would stall out when i ran with that set up. -
might need to clean the injectors, maybe run a can of seafoam through the gas. might help even things out a bit. couldnt hurt though.
thats kinda normal for plugs when you run additives or gas with extra stuff added in. i run chevron gas which has techron. most gas companies add cleaners and such to their fuels. thats most likely all the problem is on that.
the fuel injected engines have both an idle air control valve and an auxilury air valve. the iac valve is usually on the throttle body and the aav is on top of the thermostat. it sounds like the aav though, there is a bi-metal coil inside the aav that is heated by the coolant in the thermostat housing. when the coil heats up, it heats unevenly and acts like a switch to let in more or less air through the valve. also might not be a bad idea to make sure that the hoses arent cracked and that the throttle and intake are clean. might want to get that car a seafoam treatment, couldnt hurt. -
Hrmm KYB
subyrally replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
i had gr2's on my rx and i have the kyb agx struts on my impreza, i wont go with anything else for a stock replacement other than kyb. the only exception being that they dont make an adjustable strut for the oldschool cars but i swear by kyb suspension, they make a very nice product. -
Suspension and tire upgrades
subyrally replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i recommend getting 15" rims and nitto nt450 tires. main reason i suggest the nt450's is that they are inexpinsive and they handle very well in various weather conditions including rain and snow. not bad for a ultra high performance tire. id also recommend at least a 205 width tire. i am currently running the nt450's on my impreza and i have em on my pugs that were on my rx and are now on the brat. cant wait to see how well that thing does once i get it running. -
that sounds like a leak between the turbo and hte throttle body. i would check where the plenum meets the throttle body, ive had it pop off partially, enough to leak, but not be easily visable.
you never went on a ride with me through the mountains, my rx was faster than my impreza in the hills. and coming down the mountain is very twisty and there is no posted speed limit. most take that road at about 15-25mph, i rarely drop below 40. its all about knowing the limits of the car and no getting past em. then again, the rx out handles my impreza, god i miss that little car already. but yeah, stopping power wasnt the greatest in that car. oh yeah, and the hawk hps? pads are the street pads, way better than any stock pads ive seen and they work great in all conditions from what ive seen. i think they are made of a compound that doesnt require warm up to work. they do leave a bit of dusting though. -
this could be interesting, pity there isnt a big brake kit for the older cars. -
its even more fun when theyre dead:dead:
if you search in the old school forum for "5 lug swap" there should be a bunch of info on it. lots of people have done it, granted i think its getting harder to get some of the parts.
isnt that entire bit of metal that runs under the door sill, from wheel well to wheel well. im getting it all one peice and then cutting it to fit, as far as the under side bits and what not, thats going to be a bit challenging. if i do get you a set made, i might be able to bring em close to you. a lot of my family lives in the hillsville/galax area. if i ever get to go to my grandmother's again. i could bring the metal for you.
you talking about the rocker panels/?
