Everything posted by subyrally
could be interesting.
the suby dealer here told my that you cant replace em and that the drive shaft wasnt serviceable, on top of that, none of the shops in my area could get anything to match it .
anyone else need a towel after that?
A subaru owner from Sweden
subyrally replied to riverstream's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cheers mate back on topic, that brat looks hot. i like the paint job on there. -
you didnt grow up in the 80's and early 90's i see. they were like the craziest looking things ive ever seen in school while sober. -
indeed, thanks for the heads up on that gary. i need to get in touch with the guys at ram and actually spend some money, maybe once i have some to spend.
beautiful scenery and looks like a lot of fun. yeah, what is with the white cars??
im getting my clutch kit from brake and clutch of ashville. they are the only people ive found that will make one for the old school subies. and the price is less than what i can get a stock set for. as far as what i am running, i have a stock engine, spyder manifold with the xt6 throttle body, nissan 280zx fuel injectors, td04 turbo, 4" bellmouth into a full 3" turbo back exhaust, front mount intercooler for an 04 wrx. soon ill be rebuilding my headers and hopefully ill be able to start to get the parts to build my new engine, im looking at forged pistons, over sized vavles, delta cams, and a mild port and polish. there will be a few other tweeks here and there as well
well, i finally got around to taking pics of the spyder in my car. there are still a few bugs in the system, but im sure i can fix em, i just need the time to get things figured out. the hardest part to figure out will be getting the fdic (?) back in the system. the xt6 throttle body doesnt have the mounting place for it. i think that i can figure it out though. the only other problem im having right now is the clutch. its starting to slip when i put my foot into it. and now for what we have been waiting for. thats all i got for now, my batteries died and it was rather dark out. possibly more to come.
Custom Fenders for a Brat
subyrally replied to Gravityman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
any loyale or 85+ gl/dl/ect fenders will work for the rx, they are the same body. as far as the wheel arch, i think that you should leave the diameter the same but push it out a few inches, enough to cover the tires on a set of pugs, basically, i am running a set of 15" pugs with 205/50/15 tires. the stock fenders are about 1.5" too narrow. you should make the fenders about 2" wider than the stock set. if you could make em to look simular to the sti 22b or the gc8 style rally car, that would be sweet. as far as the rear, it might be a bit hard to get an actual flare in the fender, you would have to do som cutting of the fender and then make it a two peice set so that the rear doors on the sedans could open. -
you really need to do that for the ea82's i really need a set for my 86 rx. -
well, i got the manifold on the car,it runs and is a lot smoother running on the highway. i think the lack of the fdic? is causing the ecu to get a bit confised. that and the intake pipe after the intercooler keeps popping off under load. i just need to get a longer peice of silicone hosing stuff. right now itjust hasa standard turbonetics pipe coupler that is about two inches shorter than what i need. the only other mechanical issue i have is that the throttle cable is mounted too low on the engine and hits the little bar on the throttle linkage, thus keeping the idle at about 2000 rpm. i just need to finish making a bracket for that, i should be able to fix that today when i get home from the beach. ill post pics once i finally get home and if i can get the pics ontothe laptop,my pc died
subyrally was very tired when he posted, and trying to get out to the bar, just cause i cant read when i am tired, i should have remebered that cause i was looking into that a while back. i know, total noob moment, but then again, ive done worse.
so, what aplication are the shocks for?
from what ive gathered, the solinoid thingy is used when there is an extra load on the engine at idle, like say if i had a/c or if i turn the wheels while off the throttle/ or something like that. it looks like i might be able to run without that chunk. im thinking about trying to get it on tomarrow morning before work, if i am functional when i get up/.
well, i lucked out in the fact that the xt turbo harness matches with my rx harness. i figured out what the part isthat ill be doing without. i think its called a fidc solinoid. or something like that. either way, its not on the larger throttle body at all. but sofar, everything is bolting up and happy, but i still need to figure out a few of the vaccuum routings on the manifold. there are a few lines that are no longer needed but then there are some that im missing, so its going to be a challenge to get it all running right. but i think i can get it going, it shouldnt be too hard.
alrighty, i got the wiring harness from the xt turbo at the junk yard, its a direct match for what i have, even the pin outs are identical. now i just needs to figureout the idle air control valve issue. like the fact that my throttle body doesnt have a place for one
what be that throttle switch in the mpfi diagram? my manifold doesnt have the egr vavle on it but i think that the xt im getting parts off of does, basically its a complete xt turbo. i just gotta figure out the tps wiring and the idle air control, the aav is there and i just need to get the right plug connector for it. im wondering if the aav can act as the idle air control valve on my set up. hmmm. now i just need to figure out the vaccuum routing and such. eh im sure ill come up with something.
ok, most issues solved and pics in the last post. ok, so i searched till i couldnt search anymore and i think i even posted in the retrofitting forum, but so far ive no luck. ive got an 86 rx with wiring from an 87, and i am trying to figure out my way around the wiring of the xt manifold with the xt6 throttle body on it. has anyone actually got the spyder manifold to work in an rx without just swapping in te entire xt engine management? how do you get around the lack of the idle air valve looking thing that the spyder manifold doesnt have? does anyone know what i have to do to get the spyder manifold with the xt6 throttle body to work on my rx? right now, i have a early bare manifold, the only things on it are the fuel rails, auxilery air valve and the coolant temp sensor.. i want to get this thing in my car before october if i can, i might just try to get the xt turbo harness from the junk yard i frequent.
details!! i need details! and new suspension for the rx, bad.
stripped threads in cam towers
subyrally replied to nkx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
john, try a longer bolt first, if that doesnt work, then you might have to drill it out and helicoil it. if you were closer, id help you out with that. i gotta go out and reseal the rx, again. -
Brat Video HIlarious!
subyrally replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think i need to go to church now. -
i actually get cool air right there, at least i should be, there is no fender liner and there is a big hole cut through the fender for the intercooler pipes. im actually making more power right now tha the clutch likes the temps dropped after it stopped raining last night and the car was a beast, then the clutch said no more.
