subyrally
Everything posted by subyrally
  1. that rx is hot. hopefully mine will turn out that nicely.
  2. i see that you found it john. try cleaning it up really good and replacing the wires if they are bad, then let us know if that helps.
  3. ill have to give that a try when i get off of work this afternoon.
  4. dont remember what one i turned, but i remember that it didnt go very far and had no difference in the idle. either way, the throttle cable isnt the culprit, its got the full range of movement that it is meant to.
  5. thanks gary. ill give that a try if i ever get any free time. i dont know if ill solder the wires to the sensor, but ill us a bunch of dielectric grease and new wiring to the plug.
  6. i tried the screw a while back, no change. i need to replace the coolant temp sensor anyways, i already have a new one.
  7. my rx is idleing very high latley when i start it up, it used to only got up to 1700 when cold, not it will run at 2500 rpm until it warms up. then it will come down to between 1700 and 2000 rpm. i cant get the idle anywhere neare where it needs to be without the car being in gear. i tried pinching down the idle air valve hose and there didnt seem to be any change. any ideas or suggestions?
  8. cool deal will. cant wait to see some pics of it.
  9. i really want to get my rx tuned properly., its rather quick but still needs work and engine upgrades. i need more power in that car, my impreza is under powered and it even makes the rx feel slow. i got a larger turbo and some intercooles and such just sitting around waiting to go into my car, but i havent ha the tie or money lately to get anything done.
  10. id be happy to hold the engine in my rx till you can get it.
  11. hmm, you still want to try to beat will?? i might could help you out. my rx could be a willing test subject, thankfully, the body isnt rusted to hell on mine. i actually want to set up my td04 and audi tt corner mount intercoolers to my rx. either way, if you part it out, i would be interested in some parts. either way, we need to meet up someday, i awnt to see what you can do with my rx, i want a monster damnit. lol.. peace tim
  12. i think the reason for having both parts together was that the air valve has a coil the until its heated up, its hold the vavle open, thuss giving te car a high idle until it warms up.
  13. the thermostat housing will work, but the part with the hoses coming out of it is called the auxilury air valve, also known as an idle air control valve. that is what lets the car idle at a stop when your foot isnt on the gas and also controls the high idle when you start the car. im going to a salvage yard today, ill see if they have any left on the old subies there.
  14. think of it like the idle air control valve. it lets your car idle when the throttle plate is closed. also, its what controls the idle speed when the car is warming up. the car will run without it, but you might have problems at a stop or when you make a cold start.
  15. it can be done rather nicely, they have the ability to lay the stuff on thin and smooth or thick and bumpy. the texture of the liner depends of the method of spraying.
  16. thats cool dan, so, when you gunna stop by and say hi again?? havent seen you around in a few months.
  17. methinks gary is referring to me. i live ad work in frederick. i work at the new advance auto parts store on the corner of ballenger creek pike and crestwood blvd. anytime you see either a dark blue old school suby sedan or silver impreza rs, im there. hit me up sometime, im always looking to meet new people. im also always down to get used parts when people upgrade. *hint hint*
  18. welcome to the boards, good to see some one else in the mid atlantic area.
  19. hmmm, i like that torque strut, i need to cut down on the engine's movement.
