shortskoolbus
Location
Irvine
Vehicles
1997 Subaru Legacy L
shortskoolbus's Achievements
Advanced Member (3/11)
0
I replaced it because i was back there for the oil separator... lesson learned, never touch that rear main seal unless it is leaking. If that thing is still leaking this time, i'm not doing it again.. it's going into the mechanic. I did make one mistake though which i hope doesn't come back to haunt me... i only torqued the drive plate bolts down to 40 ft-lb instead of 52 ft-lb.. for some reason i remembered them as 40. I did use loctite though, so i figure it should be okay... or i hope i should say..
7 bolts sounds right.. sorry i don't have any other advice then. I don't think the seal from the factory sealant should be that difficult to break though How did you try to break it? You said you used a piece of wood? Are you trying to pry it away from the block or loosen it by knocking it to the side? I don't think it will knock loose to the side because there should be dowel pins also on the block.
just finished putting my 4EAT back in... for the second time.. changed the rear main (again) and resealed the oil separator plate since i can't say for sure what was leaking from the first time i did it.. put a thin coat of sealant around the outside of the rear main which will hopefully prevent any leaks in the event that i stupidly installed it wrong again... if that thing is still leaking, i'm letting the mechanic do it. pulling the transmission twice is more than i would like already...
Hey guys I need some help. I cross threaded one of the tabs on my torque converter the last time I put my tranny back on. Because it wasn’t in a position where I could tape it out and put a helicoil in (without pulling the tranny again) I had to just run a M8 x 1.25 tap right through it which I think just chopped off the top of the peaks of each thread.. Now I have the tranny out again I want to fix that hole. I’ve never done this before, but I think its just a matter of tapping the hole out to the bigger size and then threading the helicoil in. Do I need to drill out the hole at all or can I just start tapping with the larger tap since there are still threads there. Do I just use a tap one size up?
Few weeks ago i pulled the tranny, changed the oil separator plate... and thought heck might as well do the rear main. Well, this is what the rear main looks like today... First picture has some coolant on it thats why it's green, but the second picture is just the oil.. It's actually pretty dirty back there in general so i really can't tell for sure that its the rear main, but looking closely i can see oil at the edges... so i think it's safe to say that it is the rear main..? I learned my lesson about that seal - if it's not leaking, don't touch it. I'm just debating if i should reseal my oil separator.. i'm pretty sure it's not leaking.. but can't say for sure.
