shortskoolbus
Everything posted by shortskoolbus
Item #4 is what i got.. part numbers are not even the same... Also, while i was at the dealership i picked up another oil pump o-ring because the one in your photo didn't look like the one i had... and indeed, the one this dealership gave me isn't even the same. I'm gonna have to redo the oil pump again, damn it. This will be the 8th time i've taken off the timing belt since Friday.
well i think you run the risk over having to over torque it to prevent leaking potentially damaging the threads. but in general it should be OK. you can order them online from the dealership, though you'll pay more in shipping than you do for the washers. what's your location? no dealership near by?
It’s under that wireloom. It’s hard to find, you really have to look for it. It helps to take off the TPS, and you’ll need a offset 12mm box wrench to get to it. It needs to have a pretty big offset, probably close to 1 inch. Make sure to mark your TPS position in relation to the screws before removing it. Otherwise if you try to get a socket in there you’ll have to take off the IACSV too (at least I did). it's a PITA to get on or off, all those wirelooms are in the way.
Yes, they are OEM o-rings. I can take a photo when i get back home later, but basically the support piece wont sit flush anymore with the head the o-ring is suppose to compress into the chamfer if i'm not mistaken, but it's not, it's just compressing between the head and the support, not allowing the two metal surfaces to sit flush. I'm aware of where both of them are sounds like i just need to press it in harder? on the drivers side, i can actually see the o-ring squished out almost looks like a silicon sealant squishing out. These didn't seem that thin though..
Okay, i need to know if i'm doing this right. On the camshaft support, there is castle like thing and then flanges where it bolts up to the head. The o-ring goes on and around this, correct? As in it's meant to be installed onto the support and it sits up against the flanges that are supposed to sit flush to the head? I can see there's a chamfer on the head side, where it looks like the o-ring is suposed to compress into. The old o-rings were stuck in that chamfer and had formed into a triangular. The problem i have is that once i put the new o-rings on, the thing wont sit flush anymore. And as a matter of fact on the LH side it looks like the o-ring actually got squished out so instead of compressing into the little gap for the chamfer, it's compressing between the head and flanges. Am i doing something wrong?
well, actually, i'm pretty sure he ran over something you can see that whole side is covered in some type of tar or something and also there's a pretty massive dent in the fuel tank on that side as well. In any case, when that outrigger gets any play in it from the differential engaging, it bumps up against the bracket since it's all smashed together.
