kamnk
About kamnk
- Birthday 09/23/1990
Location
bled-Slovenia
Interests
cross country skiing
Occupation
student
Vehicles
Subaru fan
kamnk's Achievements
Advanced Member (3/11)
0
hi mine outback has problems and nobady does not know what is wrog when the engine is cold it does not have a power and the car is shaking we made big servis and changed oil, spark plugs, cabels, filters, distributur, cleen iac ventil (still in good working order), distributor(spark distributor) if anyone meybi know for such a problem please gave me idea what should be changed that the car will work
is this ej22t closed deck block
in europe we have legacy with push button 4wd and low range the gear ratio is similar to 5sped d/r from ea82 and impreza with 1.6 liter engine has 5speed awd low range transmition that gear ratio is similar to ea82 d/r
Documented: The 1970 FF-1 Project car...
kamnk replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
sounds like really bad head gasket I can not see any other thing here that can be bed -
frenken motor
kamnk replied to kamnk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
that is the only reason why I am gona build it this is gona be the first frenken motor in slovenia probably far arround thanks for that information -
it fits vith some cutting and velding
Old Rims found in back of Dad's garage
kamnk replied to cjboccia's topic in Old Gen.: 80's GL/DL/XT/Loyales...
pics -
we tested a lot of EJ18 engines and I can say those engines can not be kiled
put in ej20g engine from impreza gt or legacy turbo and you will stat at 200+hp this is yust mine opinion this one is in legacy turbo
