2.5_IMP
Gender
Male
Location
CP, MD
Occupation
_
Vehicles
2014 Outback
2.5_IMP's Achievements
USMB is life! (4/11)
After somehow enduring 12 miles of abuse, the car struck a rock, gouged its oil pan and came to a stop. Hmmmmm. Skidplate would have helped prevent that.
I think there are two Imprezas in the lead because the poll is on NASIOC. If it was on SubaruForester.org, there would be a Forester in the lead... Nice try, but JacksonRally always had the lead over Distorto in the first round, including at the time you posted whining about who was winning. Maybe you didn't scroll down far enough to see the whole poll?
"Bolt on parts" in bold for the short attention span generation... Specs: -built 2.5 with forged internals -vf-39 turbo -SPT intake -ho hum 3'' stainless catless exh. -tgv go bye bye -Odyssey battery -custom shortened PWR radiator -front end tubed and modified for better approach angle -rear end completely cut out and tubed and re-sheetmetaled for better departure angle -JR 1'' lift spacer -custom front control arms -custom x-brace for control arms -Lowrance Baja 540c gps -STI blue carpet -15'' Team Dynamic wheels -28'' BFG all terrains Please read this whole thread, look at all the pictures, and you will see why Kyle is winning. http://www.dirtyimpreza.com/forums/showthread.php?t=765 lifted wrx with lots of bolt on parts
My 73' Coupe Restoration
2.5_IMP replied to Datsunrides's topic in Historic Subaru Forum: 50's thru 70's
USPS has a 70 lb. limit. UPS will ship up to 150. -
I ended up ordering the OEM formed hoses, but I'm going to buy some generic high pressure hose for the next time something like this happens. I was waiting for you to chime in. Yes, the lines do run under the head on Imprezas. I removed the hoses this morning, and this is what I found: All clamps were tight, and not rusty. Both hoses showed no signs of damage from heat, and were suprisingly soft and pliable. BUT - one of the lines had a giant hole rubbed in it by the steering shaft. The hard line closest to the head had been bent, causing the hose to rub against the steering shaft. So, how did this happen? Before I left Portland, I had the head gaskets done at an independent Subaru shop. This the only time the engine has been out of the car, and I suspect that this is when the hard line was bent. Can I prove it? Of course not, and so I won't name names.
There was definitely no oil leaking onto the hoses. I try to keep things clean and dry under the hood. Well, until today at least. I bought the car when I lived in Oregon, so it has only been through one salty winter since moving back east. The lines aren't in the best location. There isn't much room between the lines and the steering shaft, and it looks like there may have been some rubbing. Thank you both for the suggestions. I'm going to be replacing the line that failed, as well as all the rest of the lines and fittings as a precaution.
I have a 2002 Impreza with a 4EAT that's just about to hit 135,000 miles. When I was driving it this afternoon, I noticed smoke coming from underneath the car. To make a long story short, one of the lines that sends the ATF to the cooler had developed a sudden and severe leak, and was coating the exhaust with ATF. Fortunately, there was enough left in the trans. to limp it home. Is this a common failure? I searched and couldn't seem to find much.
Yep, I am wrong.
That's not a real Weber... http://genuineweber.blogspot.com/
Only on the West Coast... http://www.lovewrightco.com/flash/blog/?p=1218
That's $75.00 for just one light. For that price, you can buy a pair of Hella 500 driving lights with everythine needed to install them. http://www.quadratec.com/products/97006_03.htm
Today ends a year long search... 1985 BRAT Gl
2.5_IMP replied to Grimm's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm confused. Are you a Brit, Kiwi, or Aussie living in NC? Or do you just talk funny? -
If only 31" tires were actually 31". 31" BFG A/Ts are 30.7. You'll find that most offroad tires are smaller than what it says on the sidewall. All your math makes my head hurt.
