kerandt
Gender
Male
Location
Missoula, MT
Interests
Wood working, gardening, old Subaru stuff.
Occupation
Surveyor
Referral
Web search
Biography
First car was a 1987 GL wagon (1996).
Vehicles
1979 Brat, 2003 Forester
Contact Methods
Yahoo
kerandt@yahoo.com
kerandt's Achievements
USMB is life! (4/11)
12
Weber swap - what do I need?
kerandt replied to comatosellama's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just used this write-up. Answers everythng. http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/ Great write-up. -
1994 loyale no spark new guy please help.
kerandt replied to gundoloyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Any moisture in your disty cap? I've also experienced weak spark (no start) from bad grounds. Particularly the coil not being mounted solid to the frame. -
drilling hubs and wheel/tire sizing
kerandt replied to lostalfos's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I thought I'd mention I first tried a set of 14" Mazda 6 lugs and found the center hole was just too tight to fit on the back. So instead I found these Nissan wheels (also 14"). I put 185/70/R14 on them. Hopefully the photos show some of the offset. Car is stock (no lift). As mentioned, I took the wheels in to Schwab loose, they mounted and balanced, then I put 'em on myself. No issues so far. I did have a rear drum from another car with two studs knocked out for a template. I also had to hand file a tiny bit on a few of the new holes where the factory studs touched. I still have winter tires on the stock 13" and this makes it easier to go back and forth.- 26 replies
Ea82 rebuild: Cylinder 2 and 4 don't fire
kerandt replied to kharris12's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Greetings kharris12. So you pulled the motor and did the head gaskets and seals. Now drivers side is not firing. I would suspect timing, but if you've checked that then next thing I would do is the compression check. Could a rocker slide out of place when you mated the cam carrier to the head? This would cause compression loss out a valve. -
Anyone have anything to say about the engine cranes HFT sells? I've been considering getting one. I'm no pro just a DIY maintenance guy. My garage is about 16' wide by 28' long but with a flat low ceiling. I don't think I have enough height for a chain hoist set up.
Pressure washer?
88 DL Black Box, Mystery Wire?
kerandt replied to kerandt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I believe it does have CC. Remember seeing some controls on the right side of the steering wheel. Ok probably not the issue then. Anyways thanks for the quick replies! Cleaned all the grounds and disconnected the CTS (tested bad), and swapped coil bracket. Car starts and runs for now. Might mess with the wire later to see if the CC works? Thanks again guys. -
Can someone please explain the function/importance of the small plastic black box mounted on the left kick panel area, it is accessed behind the fuse panel and has a wide white connector with 14 wires (if I counted right). I picked up a DL 4WD wagon, SPFI, manufactured in 01/88. It dosen't run (yet). And there is a yellow wire w/ white stripe fished up through the top left portion of the firewall. Looks like they had it connected to something in the engine bay. Ground? Power? Anyways would like to know if it has anything to do with why the car currently isn't running. I believe it's a spark/electrical issue. Belts are good. Tried starting fluid. And have swapped out both the disty and coil from a running Loyale. Only trouble code is 21 (temp sensor circiut). Sorry no pics of the box It' hard to see in there! The wire in question (Ylw/wht) originates from this black box, so why was it brought into the bay?
Hey 175eya. Yeah that sucks. When a car becomes unreliable. Makes me nervous driving around. Paranoia sets in. Anyways what kind of trouble shooting have you done? When it quits have you shot a little starter fluid in the carb to confirm it is a fuel issue? I put a weber on my '87 wagon and added an in-line filter just before the carb so now it has two. The new filter you installed was it under the car by the pump? I did replace my pump a couple years ago after it left me stranded. Car just quit with no warning signs (mid winter?). Someone suggested it could be water freezing in the fuel. I ended up changing out the pump (Napa) and factory filter and she came back to life. Never really figured out what the actual problem was and that was before the weber was installed. Another note; my weber has a fuel cut-off solenoid does yours? Good luck with the trouble shooting!
weird part and it cracked during removal
kerandt replied to goldtoof's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you have an electric fan mounted to the radiator the thermoswitch would go there. With a new radiator it would usually come with a plug there. Do you have an electric fan? Or just the one mounted to the water pump? Should have both if your car has AC. I've removed mine off the w pump and now only rely on the electric. Mainly so I have one less thing to remove to mess with the timing belt. -
I think that is called a Red-line tune up. Possibly the most underrated cure for TOD? I baby my car. I must say I am impressed. Never drove an ea82 that would top 80 and my gf 3AT will barely go 70. Were you going down hill? Anyways. Drive it like you stole it.
For those interested in a DIY roof rack there are Quick N Easy mounts available. https://www.flickr.com/photos/minicab/16096945962/ I always planned to replace the wood with a piece of square tubing and paint everything black. I was lucky enough to find the feet 2nd hand so they were cheap. https://www.flickr.com/photos/minicab/15475353464/in/photostream/
