No air to flat airbags
Glenn H replied to Glenn H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi All, I've hopefully had a win in keeping my 90 Liberty/Legacy wagon on the road & I hope the solution will help someone else. In frustration I took the car to a Subi' dealer in the hope the experts could pinpoint the apparent electrical fault. When raised a little on the hoist the bags began to inflate - it seems when the suspension is completely flat the magnets that activate the height sensors are out of range of the switches and the control unit doesn't act, raise it to the normal height range and up it goes. Unfortunately the suspension was flat 24 hours later and despite the mechanics being unable to find any obvious leaks in the airbags all they could suggest was to replace the lot with conventional suspension - not something I can afford at the moment. With the car at home I noticed air venting from the compressor inlet/vent tube while the ignition was off - I'd noted that the "End Wrench" article describing the system's operation mentioned that the solonoid controlling the venting would only be open when powered and reasoned that something must be jamming it open. I removed and dismantled the compressor unit and blew a collection of dried bugbits out with an air gun, the dryer canister also yealded a pile of brown grit which I suspect came from its corroding insides. After re-assembly everything seems OK so far. Cheers, Glenn H.
Glenn H replied to Glenn H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHi John & Co, actually all four bags went flat simultainiously - drove to work fine & twelve hours later I had a low-rider wagon! Could it be a height sensor fault? When I press the button on dash the up arrows flash briefy then the raised position is highlighted although nothing has moved. Cheers, Glenn H.
Glenn H replied to Glenn H's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for your input guys, considering some of the roads I use its possible an earth/ground connection has rattled loose. Incidently, where does the air vent from when the vehicle is lowering? Cheers, Glenn H.
Hi Folks, I hope someone can help me out with this one. The airbag gremlins have attacked my 1990 Legacy (Australian "Liberty"), there is air flowing to the inlets on the front strut control solonoids but nothing coming out (can I check the rears without dismantling the strut?) . Is this symptomatic of a control unit malfunction or simply a leak somewhere? Cheers, Glenn H.
Hi Folks, I hope someone can help me out with this one. The airbag gremlins have attacked my 1990 Legacy (Australian "Liberty"), there is air flowing to the inlet on the front strut control solonoids but nothing coming out. Is this symptomatic of a control unit malfunction or simply a leak somewhere? cheers, Glenn H.
Glenn H
