Everything posted by 1-3-2-4
I will be upgrading from the stock struts to the KYB GR2's I will be lowering the car at the same time (Oh My!) I was going to do H&R springs but they are a little bit pricey. I was looking at these here http://cgi.ebay.com/ebaymotors/Subaru-02-03-Impreza-WRX-M2-Coil-Lowering-Low-Springs-_W0QQcmdZViewItemQQhashZitem563cec40d7QQitemZ370389303511QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
When I do get my exhaust I wonder who I can take it to.. I have this one place in mind but a little unsure.. for one thing the shop is in a so-so part of the city and I don't want them chopping up the catback. http://www.insiderpages.com/b/3712052722/yankee-discount-muffler-bridgeport http://maps.google.com/maps?oe=utf-8&client=firefox-a&q=1290+Boston+Ave+++Bridgeport,+CT++06610&ie=UTF8&hq=&hnear=1290+Boston+Ave,+Bridgeport,+Fairfield,+Connecticut+06610&gl=us&ei=1zkJTIj6E8X6lwezu-2JDw&ved=0CBQQ8gEwAA&ll=41.193317,-73.169975&spn=0.012401,0.033023&t=h&z=16&layer=c&cbll=41.193319,-73.170099&panoid=3038PmSiTzlCViVOIqbiHw&cbp=12,180.45,,0,5
maybe I missed it but did you paint the hood flat black?
When you drain drain all the fluid out check the drain plug and clean the plug off of metal shavings (it has a magnet on it to catch metals) once that is done replace the plug and fill the transmission up with GL-5 fluid to what's listed in the manual.. Also make sure the car is on level ground. As for driving the car after the fluid change I went right on the highway came back home and checked to make sure I had no leaks.
Here is my car on a Dyno Borla replicas and a Subaru Bosal 2.5GT catback. As you see it's not that loud.. And yes my car is iffy getting into 3rd because the shifter knuckle is worn.. If you move it into gear like any other manual you will get this 95% of the time.. The key is to let it glide in check out that bouncing at 6:30
hmm I forgot about the pinch bolt I will give it a shot of PB blaster but would a impact help for it? i hope the rockauto order will ship from someplace that's not too far. I can pick up a pickle fork local will feel nice to have a tighter steering again and yes I do know I need a alignment.. good thing I'm not yet running on my 16's yet but still on the stock 14's
A little update now that the weather is getting warmer.. having the car on the ground I decided to try to tug the driver's side tie rod back and forth take's a bit of effort but you can hear the clunk sound. I think I will have everything.. Inner & outer tie rods and lower ball joint & rubber boot covers Only thing I cant figure out from picture is when I remove the lower ball joint do I need to support the steering knuckle in any way?
MT no more AT Subaru's for me The only work I've done so far was replace the radiator and water pump along with doing the timing belt and knock sensor. Going to order the GR'2s in the morning I think my last tire rotation really caused the rear struts to leak whatever oil they had left in them. my only concern is removing the springs because they are so old I know they had a voluntary recall over the springs and rust in salt states which this car has seen enough of.
