Everything posted by 1-3-2-4
Removing front crank seal from oil pump housing
1-3-2-4 replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFor me I removed it with the oil pump still on but I used a screwdriver and was VERY careful not to nick the surface. It came out very easy compared how the haynes manual said and stories I've heard online. it was in and out in 5 min.. took me longer to clean the inside of the seal housing then it took to get it out.
Does the parkinglight (font) have a relay?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will check this in the morning.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXfuse 23 in the main box is for my AC fuse 5 in the car is for the tail light right side.
Clunk sound heard when off throttle
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSO I was under the car and I checked the ball joint.. I don't know what to say.. it sounds like it's coming from the CV axle or the ball joint.. the car's weight makes the clunk sound louder then me tugging on the front suspension so it made it harder to hear.. If I can find my long mic cable I can grab the clip since the mic in the car you can just barely hear it. Oh yeah and my boot is split.. maybe it is the tie rod.. but the passenger side is also just as bad as well. Driver's side shown here passenger side
A/C recharging question
1-3-2-4 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah I have to check the FSM again to see how much is needed. while I was under the car I also checked out the condenser it's got road grime on the passenger side of it and driver's side as soon as my gauges come I will be checking the pressure.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm about to go under the car here in a few if I lift the front end up would I be able to tell if it's the ball joint by trying to move it? or if it's the lash adjustment that's needed or the tie rod?
1-3-2-4 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyep I know where the evaporator is.. I just cleaned about 4 inches worth of pinestraw and leaves from the airbox.. it was blocking the whole evaporator. I don't have my gauge set yet but I'm about to go out now to check if I see any oily deposits around any of the fittings. I hear the most common leaking area is the o-rings on the compressor. my compressor is a Zyxel. also yes the factory service manual really helps. *edit* What did you use for compressor oil?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI will check tomorrow since I need to do a little work on the car and yes I have a voltmeter.. never leave home without it!
1-3-2-4 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXquestion.. I'm guessing the best way is using uv die but the evaporator can just go belly up on it's own? i found a load of leaves and pinestraw which was about 3 inches deep where the evaporator is.. cleaned it all out but still have poor cooling.. I notice when I turn on the AC now I hear a slight hiss from the area sounds like the expansion valve. having said that I plan on getting some Manifold Gauges and I was looking at a vacuum pump it is rated for 75 micron/10 Pascal.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXedit
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCorrect and already changed the bulbs had no effect. And no they don't come on in the front if you use the parking switch or the switch on the stalk. Regardless if the engine is running or not.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhmm I did not know the flasher unit was tied in with just turning the parking lights on..
Still trying to figure out what is wrong, when I turn on the parking lights my rear lights come on with no issues however my front's don't at all.. but here is the thing when I turn on the turn signal or hazard lights the front parking lights will flash normal but they just don't work when the turn signal is not on and the parking lights are on.. A quick search on NASIOC shows a few have this issue but no follow up's have been done regarding it.. all my fuses seem to be good as well as the under hood fuses. What should I check next? It's been like this going on 3 months almost. My car is a 1995 Legacy L wagon.
1-3-2-4 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf it has not been said don't forget to add oil to the system as well.
cylinder compression seems to measure low
1-3-2-4 replied to 98sub2500leg's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I've turned the engine over by hand with the crank pulley only unless you like sore hands and cuts not worth it..
fuel pump issues 1995 Legacy
1-3-2-4 replied to bfd's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure if I had this same issue since after replacing my T-belt everything was fine.. but I came up to a stop sign which was on a little incline with a 1/2 tank and the car just died.. I tried to start it and nothing.. so I put the car in Neutral and back up. From that I got the car started but it was rough.. I got it back in first gear and took off without it stalling.. that was about 2 months ago and never had any issues since then.. but then again I found a hose from the valve cover that was disconnected as well.
1998 Legacy 2.2 Timing Belt Broke......internal damage :(
1-3-2-4 replied to wildwagonz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep hat little mark for me was covered in grime and I was using the white mark instead.. took me a total of 8 hours total (I started late in the day) after I found the mark on the crank car pretty much started up.
It only happens when the body of the car shifts forward when you lift off the throttle under light or moderate acceleration. It's coming from the driver's side front it sounds suspension related but it's hard to tell which component it is. I can provide a sound file of it when I'm able to get home. Oh and the car is a 95 Legacy L wagon
New Jersey Devil Chase
Yeah let me know when another one is going to be planned.
Wagons only - post your pictures here!
1-3-2-4 replied to kevinsUBARU's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFinally I found this thread and I can post a larger size then my avatar.
AC receiver/drier question
Ok on my 95 Legacy L Wagon I have a R134a system.. from what I read you should not use the receiver/drier to check to see if the system needs to be charged? Because what I notice is which the compressor turns on the sight glass has like a white froth that shows then it's back to clear with hardly any bubbles when the compressor is off.
help with fan blower area
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyeah with a glove and a little help from the blower motor with the blower motor resistor taken out I turned the speed on high and for the stuff I could not reach it blew it out right on my face after I was not expecting that. It's much better now and my eyes don't itch while driving. Oh yeah and this is what came out!
Long story short I was only going to replace a light which finally had me removing the blower fan then to removing the resistors for the blower and that's when I noticed I have about 2 inches thick of leaves and pin straw.. I find it hard to believe that some kind of rodent was in the car? Anyways the car is a 95 Legacy L wagon I have no cabin filter... my issue is how can I remove the whole box that the evaporator is in since I have no shop vac.. this thing is completely blocking the whole evap.. maybe that's why I have no cold air?
Bad car battery? Or maybe not?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the battery is still going strong!
Best Deal You Ever Got On A Subaru?
1-3-2-4 replied to roadsubiedog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpaid $400 for a 95 Legacy L wagon I spotted on Crag's list right after i posted a wanted ad for a 97-99 Outback wagon.. Deal was just too good to pass up and the best thing was it was the 5 Spd which is hard to find here in the North East. Only repairs needed was the exhaust and waterpump which I did I brought the car when it had 198,067 and it now has 199,689... owned it a little over a month and 4 weeks now.
