Everything posted by 1-3-2-4
ej22 prices
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
After all this I'm seriously thinking about getting an oil pressure gauge, took the oil pump out sitting on my bed at the moment. -
ej22 prices
Damn plug for the engine block heater rounded out.. My Ej25D has a block heater.. Only thing I can think of is wielding a socket on it and getting it off that way, but then someone said a stay current can wield the bearings of the motor? First I've ever heard of that.. -
I had something like that happen 3 years ago, I felt a shimmy in the front wheel, and it was summer so I had the window down and going around the curve and I saw my lug nut fly off across the road.. It sheared the lug nut.. It's a pain to get out with the ABS sensor on the hub but I did it.
- 27 replies
- lug nuts
- broken studs
(and 1 more)
Tagged with:
I already have a dealer front crank seal.. it's odd when I went long time ago like 2 years ago and did the O-ring for the oil pump on the Ej25 they gave me a blue looking seal it looked nothing like what I'm seeing in the picture here.. the seal looks almost like the oil pan return seal. It's been awhile.. Yeah mine looked like this one http://beergarage.com/imgs/Suby/OPump/16.jpg 806919050 PN for the o-ring behind pump
ej22 prices
I have a question should I or should I not replace the seals for the cross over pipe for the coolant? Now on myself I've never replaced any and my EJ25 had 265K on it.. I only ask because I heard those bolts that hold the pipe down have a habit of snapping. -
^ My friend I let him use my air compressor, mind you I've had it for 3 years now and he let it tip and it broke the filter as well, so now I have to replace it with a metal one. Now having said that I'm about to pick up the 750Lb engine stand tomrrow so I can start tearing down the EJ22.
ej22 prices
This is the Ej25 I'm not sure oil got anyplace else other then almost on me, if I remember right the injectors wont spray fuel in the cylinders if the coil pack is disconnected right? -
ej22 prices
Since this engine has been sitting for who knows how long.. when you have the pan off should I squirt a little oil on the bottom end? I'm not sure how long it takes a full dry system to prime with oil -
ej22 prices
Oh well now I have to wait a few days until it arrives -
ej22 prices
Got the pan off, the screws are fine, oil pickup had a lot of things stuck on it more so then I've seen in other peoples pictures.. In my replacement pan it comes with a gasket for the oil return but it comes with two smaller gaskets which I can't figure out where they go.. I thought they would of been where the oil pickup goes with those two screws. Does that gasket on the oil pickup tube need to be replaced? -
I would assume it's because the compression would be the highest and that's where HG's that are failing tend to fail and blow bubbles.
- 25 replies
- EJ25D
- EJ25D overheat
(and 1 more)
Tagged with:
