Everything posted by 1-3-2-4
Misfire 1 & 2
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I'm pretty sure the heads are still good right? Need it for my EJ22 project. -
Misfire 1 & 2
You know what was funny was 2 nights ago I noticed between a certain rpm I hear a sound like you know piston slap on a cold morning but any higher or lower rpm it went away.. I did make a short video, power level was really down the motor made sharp metallic sounds, in which I could feel in the throttle pedal.. It's hard to tell if it's a piston or the bearings, because the fact that all the other cars I heard with bad spun bearings at least they still ran at idle.. mine would die as soon as I clutched in.. it squealed like a banshee.. -
Misfire 1 & 2
Lol time to move to the ej22 now.. I wonder if I should tear the 25d apart -
Misfire 1 & 2
Car first stalled coming off the the off ramp I was able to get it started then move again then all hell went loose. -
Misfire 1 & 2
My bearings are GONE! Repeat GONE! -
Misfire 1 & 2
Plug wires are subaru brand and a year old.. plugs are NGK platinum and 5 months old. I will have to get a picture of the coil pack -
sheeez it seems like the gauge loves to have at least one warning light lit... Not any sooner I finally fixed my 2 long year ABS light I get a CEL not too long after I filled up with fuel, The light has been off for like 2 months now.. being it's 1&2 it's on the same coil? My coil had some arc damage but that's on the connection for cly 4 As far as driveability nothing has changed. The interesting thing was it started out as only #1 at first then #2 started to show up.
Ok this time he sent it off FedEx and I have it in my hand now, must of came while I was sleep.. so going out to install it now it seemed to have come off a '99 outback You know the funny thing was on my long trip back from S.C. the ABS light never came on in that 650 mile drive.. that's nuts.. But yeah I hope this fixes the issue but I did not really mind with all that snow we had early in this year.
I notice it only really happens when the car is facing uphill and at idle. As soon as the car engine speed goes up it goes back down. Now the upper radiator hose seems like it has too much pressure in the hose. Not sure if it's because of my radiator cap since a part of the rubber that goes around the spring part ripped in one area.
I saw the wire but it was not the pin but it was reversed so I ended up finding it with my meter, yes it was brown/yellow but not in the pin slot like the manual showed or you said. I was on my way to putting parking sensors in the car but geez that stupid thick styrofoam right behind the bumper.. it's not as easy to get into the car (passenger side rear tail light) from outside the car
Ok I will check tomorrow I'm not going to put the camera on just yet because I have to switch out the hatch.. which btw do you have the part number for that part that always rusts out the one that the handle mounts on? both my lift supports never raise by themselves so I always have to help them but at least it stays up! I assume it's easy to swap the locks?
The reason why I ask this is because on the back of the head unit is a wire I need to tap for the unit to know when the car is backing up so it can switch to the camera.. it's not a long wire it's maybe about middle ways of the center console.. the reverse lights must get some power from a fuse box or something.. I just don't remember where the switch was when looking at the shift boot, On my other transmission I took out the neural and reverse switches but just can't remember where and what pushed on the switch to trigger it.
