Everything posted by 1-3-2-4
The car is a '97 as in the sig, I have the service manual so I know what the codes are, I did clear it and only the 26 code comes up now. Also back in the early summer I pulled the sensor off and it's fine, the sensor I repeat has no resistance, I waited as long as I did because I was not in a rush. http://www.ebay.com/itm/221284832140?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
So after months of looking finally found a sensor on ebay.. the codes I get are 26,56 & 41 I think.. I was wondering if the bad sensor can do this? I tested the resistance 2 years ago and I know it reads 0 ohms, but the funny thing is sometimes the ABS will work for a little while or just not at all.. I suspect it's just cheaper to do the sensor first (yes I cleaned it) I guess $38 for the right rear is not bad.. for some reason this seems to be the most expense ABS sensor on the car.
I use a 1/2" air impact.
One thing that annoys me is the AC button it's like it's something sticky on it and it's slow to come back up when you turn the AC off but moves faster when the car is hot to almost feeling like it's not sticky at all.. How can I fix this without having to take the whole switch out only to find it's something else? Another thing is I've been noticing now that when I change the air position the position wont change right or it will get stuck between settings like vent's and floor.. or if I have it on floor and change to vents it stays on floor.. i notice if I mash on the button hard enough then it's not a issue. I never seen this happen on any of my Subarus before.
