Everything posted by 1-3-2-4
damn I forgot all about my buckets in the drivers head and I put the head cam side down and went to pick it up and they got all mixed up :-/ nevertheless I got the drivers head off.. jesus I weigh 125lb and I was putting almost all my weight on the ratchet... I bent my copper pipe... cool thing to note is I did not know the shortblock had numbers above what cylinder is what. Hmm seems like I got some warpage.. going to recheck again after I clean the head.
I just checked the valve clearance and this is what I got so far.. Drivers side Intake: all 0.20mm Drivers Exhaust: Starting from the rear of the motor 0.25 0.18 0.25 0.13 Passenger Side Intake: From the rear forward 0.18mm 0.20mm 0.20mm 0.20mm Passenger Exhaust from the rear forward 0.18mm 0.18mm 0.25mm 0.20mm
I'm still scred to pull the timing belt still.. it seems like the drivers side jumped one tooth? the crank is set to the mark and the passenger side is right but the drivers side seems to be off.. Having said that the cams looks like this when parked? It's not going to snap out of control when I remove the belt is it? It's a Subaru Belt so no telling how long it's been on.. all I have is when this car went in for service at like 66K lol.. driver's head
haha yeah I was just looking at the amount of views this thread has like a few days ago
LOL true about the no rust also air ratchet FTW! I did very little wrenching however I hit my knuckle getting that top AC bolt to break loose and when it did my wrench hit the High pressure line and it started to hiss so i snugged it a little and it stopped. it turned out to be very nice.. they were saying thunderstorms and all.. I did hear a little but only got like 2 min of drizzle and the sun was in and out.. Now tomorrow might not be so good but hopefully it will be sunny again
Not sure if you seen the thread but axle? it seems too far forward and too wide to be an axle. http://www.ultimatesubaru.org/forum/showthread.php?t=124667&page=7
yeah man I really hate the USDM tails Having said that im home I finally got the engine out which was pretty simple lol.. I don't know what the hell exploded under the car but caked grease was ALL OVER the crossmember... it took me like 10 min of cleaning to get it clean... The good thing was I ran into no stuck bolts as far as the tranny to engine lol I was expecting bad.. last is the seller lied to me about replacing the clutch.. when I post the pictures you be the judge.. This is my first time pulling a motor and a manual at that but this clutch disc feels cheesy.. So I signed up for Amazon prime 1 month trial so i got my clutch kit coming in tomorrow next day air for only $3.99 lol I gotta make sure after the month is over to not renew it lol $79 is steep.
craap I had to stop tonight because I did not know what size hex those screws are for the steel rear separator plate. I got as far as cutting open the sealant and seen that none of my allen wrenches fit. Now as far as that EGR line to the head I got the lower one out by using channel locks since my 17mm flare wrench was just rounding the nut.. I haven't done the top one yet.. I've been using liquid wrench which is meh.. my kroil wont get here until it's too late but at least I got two large cans. I have a lot of pictures to follow.
maybe the impreza model has that bolt and I don't? Here is what im talking about Where it says lower trans bolt you see it has two in that area I don't I just have the bolt and speaking of that someone was smart to put never seize on it but the passenger side bolt is missing/ http://www.rs25.com/forums/f105/t63237-diy-engine-removal.html
I'm doing the drivers side bolt for the tranny.. but unless I'm in the wrong spot I just see the nut and not the bolt & nut which the bolt would be above the nut? Unless Subaru changed something which I don't think they did.. but the whole underside of the car is covered in oil/tranny oil and whatever the hell was leaking from the motor.
