Everything posted by 1-3-2-4
Forester XT vs a Tribeca for long drives
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's what I was thinking too.. I wonder if the EPA estimates are with the car loaded up?
Having a discussion right now about which one would be better for long trips as far as fuel goes.. So which one wins out? I'm pretty sure it would be the forester XT
HF engine picker
So it's doable in a sedan then? I still have my coupon for $100 off
HF engine picker
Well #^%$ my motor is overheating now while at speed on the highway (first time in 3K) I might have to take a sedan now... Now I've never seen the boxed up one in the store but will it fit in a 95 ford tarus? I was going to buy it first week in July but I'm going to buy it next week. Hopefully they have them in stock
noticed my car is overheating more now.. not sure how a engine lift is going to fit in a sedan if I have to take this other car... Car stumbled after I moved the fluid back over to the radiator would I would guess mean coolant is getting into the cylinders now.
Oil pan screws
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've been lucky so far no bolts have snapped yet but why risk it? only a few $ in screws.. I need to put a new pan in anyways
A/C compressor oil
intake is always the low side
Hmm what's out of alignment?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNice I just saw in the body section of the FSM they give measurements of how far the tram tracking gauge should be.. but that tool is too much so a tape measure will have to do.
2.2l legacy missfire
1-3-2-4 replied to Scotty1419's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoxygen sensor? I had a friend last month complain about the same stuff to me.. called me in a panic.. however she had a CEL How about checking out the oxygen sensor? her car was doing the same stuff lack of power when going on hills and she had a misfire on two cylinders (can't remember which at the moment) but after she did her plugs, knock sensor and oxygen sensor she was good to go.
My turn signal
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHah it's true I bet if someone did the statistics on that stuff they would see!
My turn signal
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit's just annoying.. I guess this person did lots of left turns and always used the turn signal unlike BMW owners
Intermittent Overheating
1-3-2-4 replied to davis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX^ wow that's pretty ballsy haha
A/C compressor oil
Only fill it back up to what comes out.. I know it sounds stupid :-/ When i did my AC system in my 95 legacy the FSM showed how much oil went into each part of the system.. I do remember the evaporator took the most.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI pulled the headlight out today to see a bit more How it should be... gap with the support
Help With Shifter Return Spring
1-3-2-4 replied to JazzBass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo problem
1-3-2-4 replied to JazzBass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo because you wont have room put the car in 5th. and it's best to hook the spring on the far side then hook it on the washer. took me like 5 times before i got it to hook... it's a pretty stiff spring so if it pops off make sure you can find it!
Oil pan screws
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThank you very much
Oil pan screws
Does anyone know the size of them?
1-3-2-4 replied to JazzBass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's doable.. it's better for space if you have the shifter in 5th gear.. I know I thought it was impossible too.. Lucky for me I will be getting a new transmission in July so I can have everything on the ground to look at.
1-3-2-4 replied to JazzBass's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not going to help that much with slop in gear.. you need a new shifter knuckle it's the one with the 2 roll pins in it.. about a $60 part if I recall..
Stock cooling fan CFM?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh I see.. well I was going to ask about slim fans but a person who tried them said they pushed no harder then stock.
For the EJ25 or Ej22 anyone know what the stock fans push? is it worth while to upgrade to a higher CFM fan?
Viscous Coupling Questions
1-3-2-4 replied to Tmb9862's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXheh I never know they had that set up here
Help buying new clutch
1-3-2-4 replied to nyorkster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't order from Amazon often (last time was 2004) I was hoping it would go down a little more but I guess that does not happen much with Amazon.
1-3-2-4 replied to nyorkster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs that the best price you can find for it on Amazon?
