Everything posted by 1-3-2-4
  1. With 189K on the motor, she is looking for another motor for less miles now I've told her she would be better off sticking with what she has (providing it was not crazy overheated) then trying to switch motors.. Since she has a '95 ECU I forgot what options she has engine wise? I'm pretty sure she has to stay Phase I for the motor.. She moved to TN awhile ago from CT so I guess it's not that easy to find stuff. And she thinks 189K is high mileage for a motor I will link her to this thread.
  2. So bear with me.. OK a lady who has a '99 Legacy SUS sedan had what she thought was the timing belt done.. I got contacted because the car runs rough now.. I check under the belt cover and noticed the timing belt was NOT changed and just the idlers and pulleys changed and the old belt put back on.. Timing was about 4 teeth off on both sides.. OK so I go in and put the belt on and line up all the marks.. I noticed the drivers head as some valve ticking which I suspect the other guy rotated both cams in the same direction.. So after getting the car started the idle was pretty high like 1500K and ended up going normal or so.. but clearing the code later had it come back up as a pending code.. So now upon starting the car again the idle was bouncing from 1500 to 2K every 3 seconds or so non stop.. I assume it's the IAC that needs to be cleaned.. but get this the guy used RTV to seal the intake manifold.. Now I have the code for the knock sensor and P0507 which is about the idle too high, I assume the rough idle (when it does idle) is due to the knock sensor? I already ordered the sensor but I was just curious.. and crap I just forgot I have a brand new spare in a padded envelope.
  3. JDM taillights incoming from Poland sometime this week.. I ended up getting the whole set for $199 about the cheapest I could find.
  4. So that's where that hissing sound is? It always sounds like it comes from the back of the pump.
  5. Yeah drilling a hole for the wing is something I don't want to do since I don't want to be off or anything like that.
  6. Nope but going to replace the hatch and hood before I paint the car so I will be finding one with a wing.
  7. My car started doing this about 2 weeks ago.. I can make a video but it's really annoying it seems to be coming in the center just behind the parking light switch. Still does it when it's 48 F outside.
  8. Nothing to report, I think I'm going to take my vacation again this year like I did last.. save the $1K and buy the first batch of upgrades
  9. Thanks, I love it too but this salt now has been causing havoc on my already rusty body panels... going to have to address those really soon!
  10. I plan on replacing it it's just the sound of it rattling on the pipe and moving around is driving me nuts and plus it cut the outer shield on my oxygen sensor
  11. I never understood that heat shield, for the cats I could understand.
  12. Heat shield for what? the rear drive shaft? most heat shields are under (covering) the exhaust and not above.
  13. I ended up returning everything and just ordering this which will be here Monday http://www.amazon.com/gp/product/B00271N7OG/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 You can see on my picture attachment the hump part of the socket is why it wont fit to reach the bolts because it's too fat to fit
  14. You that shield that between the center exhaust pipe and the drive shaft? Is it really needed? Because the snow has pretty much ripped it apart and it no longer has the mounting tabs on the bolts so it just rattles or it will move in a position that will start to pull on my rear O2 sensor wires.
  15. ha 60 is nice! Here is the starter repair I took the pistons out of the Ej25, turns out I had a long drill bit.. like 15 inches long and it was 1/4" pins came out real easy. Now I had to order online a 12mm 12 pt thin wall socket because no stores here had one that was thin enough to get to the bolts where the water jackets are.
  16. Yes I know but my 1/2" socket won't fit where the water jackets are. Im not sure if they make it in 3/8"
  17. Wait a sec... I guess the socket needs to be 12 mm 3/4"? My 1/2 is too fat.
  18. Found a clean enough spot and took the starter out and replaced everything, now just time to put it back in.
  19. Yep I got all those off I just need to take off the 12 mm block bolts and the one on the back part of the motor.
  20. Connecticut we have at least 24 inches total so far. . I have to do it today because I stalled on a hill and was unable to start it again.. because yesterday was so light in traffic I just parked in the middle of a heavy road hit the starter and that was it
  21. Thanks, I assume that bolt on the back side of the motor needs a 12mm box wrench?
