Everything posted by 1-3-2-4
haha I was hoping you were still active here did the dealer have the linkage part on hand or did they have to order it? I have some punch pins but I have to go check to see if I have the sizes you listed.. interesting I did not know it was two pins. If it keeps raining im going to have to put up a huge tent.
Show off your roos Mileage!
1-3-2-4 replied to beataru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
gggeezz 650K thats amazing -
That is not true about the dome piston thing about these engines. Ej25 from a 97 Outback interference engine http://home.comcast.net/~skipnospam/images/15-block_from_drivers_side.jpg problem is that and the valves can hit each other say a belt broke it's still going to have some movement which will for sure cause one of the cams to be off in which they hit each other plus the piston.
From the service manual if I have it, it would be under the kick panel on the drivers side? I can't tell if a after market alarm was installed because under the hood you can see here is a speaker but I'm not sure if thats the stock location.. In this picture it's right behind the MAF And inside in one of the blank panels is the red security light but does not have any words on it. having said that does anyone know the part number for it?
flashing CEL
1-3-2-4 replied to FLYRYGUY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Go get the code read free at autozone/ advance auto flashing means it can damage the catalytic converter does the car feel like it misses? Did you happen to change the spark plugs? -
Ha I dont need to go that high but must be sweet
I need to put the car on the stands front and back to test something after the transmission is back in.
hah I think I will have to search for some wood I had planned to get the trans jack and the jack stands at the same time.
So I will be buying my tranny jack next week and I need 2 pair of jack stands. I was looking at getting the 6 ton set from HF due to it's lift range http://www.harborfreight.com/automotive-motorcycle/jack-stands/6-ton-jack-stand-set-38847.html It's min height is like the max lift for many jacks My concern is having enough lift to get the tranny from under the car.. Is the 6 ton overkill or can I get by with the 3 ton with it's 16 3/4" lift?
spam? Anyways I'm about to order a few parts from Subaruparts and just my luck the friken grill clips are going to take longer then the other stuff.. Anyone know if dealers keep this on hand or is it all something they need to order? Anyways as far as the transmission side of things I have the two clips in the order for the TOB but what about that clip retainer which looks to be behind the clutch fork? Should that be ok? That shift rod bushing I will just get locally once I can figure out which design it is since it appears to have changed mid model years.
1997 Outback
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
When i get the car on Tuesday I just wanted to know maybe it's 97 issue or what.. It's been 5 years since I had a 2.5 motor but when you just tap the throttle the revs hang a bit before coming back down. I don't think I ever remember that happening on a 98 forester or my 03 I had.. maybe throttle body needs cleaning? -
Thank you for posting that piston picture people always thought I was nuts saying the EJ25 hardly had any piston skirts. from what I hear the skirt would hit the counter weights if they were longer on the Ej25.. I've never seen a Ej25 out and opened with the pistons at BDC but I'm sure it would be close.
1997 Outback
well %&*$^&( I have to wait until Tuesday now to get the car.. DMV says they need a pass from the town hall stating my property tax is up to date on the last car before I can get my plates.. So effin close.. I would of made it had the stupid mail guy did not come with my certify letter at 1 Pm.. town hall closes at 3:30 and closed weekends and the DMV is closed Monday... -
1997 Outback
sweet I just got the title and bill of sale so away I go to pick the car up! at least it's going to be a nice day unlike tomorrows rainy day.
