Everything posted by 1-3-2-4
misfires
1-3-2-4 replied to wesmay's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Wow never seen that but maybe its the wasted spark setup that makes it run like poo? -
misfires
loong time ago when I had my forester before I knew better I installed bosh plat plugs in the car.. that car would misfire so much it was beyond stupid.. So I went ahead and swapped out for NGK I think coppers or whatever for the 98MY anyways car ran MUCH better. -
misfires
wait wait.. What bosh plugs are you using?? i hope its not the platinum plugs. -
Towing
1-3-2-4 replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
its nothing wrong with the car towed with a dolly as long as the rear is not on the ground and the front in the air and no wheels turning it as if it was on a flatbed. unless you mean one that is a hitch mount.. but still same rules apply the rear still needs a dolly of it's a hitch mount dolly -
Towing
I had a dumb rump roast tow truck try to tow my car after I told him many of times the car wheels will lock up.. So dumb rump roast proceeded anyways to tow (about 2 miles to my house) and we hardly got 50Ft before he heard the rear tires skidding on the road (front end raised) SO I had to wait another 1 hr and a half for him to get the flatbed because he was the only one in town.. My thing is why not just get a flatbed out no matter if its FWD or AWD or RWD? it makes it failsafe.. And yes as soon as I replaced the fuel pump I did check the center diff and it was ok. having said that Ive never seen anyone use a dolly before.. -
maybe because mine lasted 48 hours before it crapped out on me.. and it was not like I had any heavy loads on it.. I took it and got an interstate and that was the end of it.. it was the walmart maxxstart battery it's a maint free battery
if the car starts with a jump it's not the wire or the starter or anything else.. you just have to face it you got a bum battery :-\ When you did jump it did you test the alternator output? It should be putting out anything above 12V rev the car to 1500 rpms and test the voltage output.
RIP Legacy
1-3-2-4 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
wow man you tore it down good! I would of LOVED to pull my engine so I wont have to spend rip off prices for a used ej22.. I have plans for a build but just incase something blows up I don't want that to be my only motor. -
I only ask because I should of listened to everyone not to get a battery from walmart.. started fine but the next day no start and click click.. traded a brand new battery for an interstate.. well more like I had to spend out another almost $80....
not a walmart battery I hope
sorry long night and a little sleepy but your problem is just the level in the overflow tank? My past legacy had that same issue.. it would always suck from the overflow tank but not any missing under the cap which btw was a brand new cap I replaced.. car never overheated I never could figure it out.. and letting the overflow run dry had no ill effects as well.
