iransom
About iransom
- Birthday 06/21/1963
Contact Methods
Website URL
http://
Location
Denver
Vehicles
1992 Subaru Legacy
iransom's Achievements
Member (2/11)
10
Is there a way to manually check the codes? If so please provide the steps. I was told that the code reader for the year of my car 1992 is expensive. Is it possible to rent one? I will check with the different auto parts stores today. The area where the crankshaft sensor is located is covered with debris. Could this affect that part? Thanks for your responses. Info only: My car has over 234000 miles and the timing belt was replaced last year.
:DI have a test light and a digital multimeter. Please describe how I would check for the 12 volts from the battery to this yellow cable and where is this cable located. Is it the small three pin cable that plugs into the ignition coil cable? So I need to have the ignition on but not trying to crank it. I checked fuse #16 (ignition) and it was in good condition.
I conducted an ignition coil test using a digital multimeter on the three-terminal connector from the coil. Terminal 1 & 2 I got a reading of 1.2 and for terminal 2 & 3 I got a reading of 1.1. Haynes manual recommended 0.63 to 0.77. Could this also be a cranshaft sensor problem? A few times recently while driving on the hwy it was hard to accelerate and almost stalled.
Thanks for your reponses. We check for sparks but no sparks. The ignition coil and igniter came from a 1992 Subaru Legacy at the salvage with 274000 miles. I am going to take the coil to autozone for testing and is there a way to test the igniter? Could this also be the fuel pump relay going bad?Thanks for your responses.
I have a 1992 Legacy. Its automatic. Last Thursday it stalled on me in traffic. It had gas in it. As i tried to start it, it would crank but not start. I had to have it towed. Today, I used a test light on the coil and got no light on the two outside wires. We changed out the ignition coil and the igniter but with the same results. Now we are looking for the fuel pump relay but cant find it. Can someone provide the location for the fuel pump relay and any other ideas would be of great assistance.
Sorry, for not stating that its a 1992 Subaru Legacy. I am getting a strong order smell inside the car. It happens when its warm and cold. I haven't notice any fuel leaks. How can I tell if its the EVAP canister or the EVAP Purge Solenoid? Also, where is the EVAP Purge Solenoid located? I also get the smell through the vents.
