loyalewcheese
About loyalewcheese
  • Birthday 04/21/1980
  • Location
    seattle
  • Occupation
    carpenter
  • Vehicles
    92 legacy 94 loyale
loyalewcheese's Achievements
Member
Member (2/11)
0
  1. I lent my car to a friend. He burnt the clutch out. gone. no more adjustment. The pressure plate and bearing and such are all newish. 15,000 miles. i could just replace the friction disc don't you think? its only $80 more the whole kit. do you think its worth it?
  2. i just did this. I used 98 outback struts, springs and top hats. the fronts bolted rite in. same top hat as the legacy. I used some camber bolts on the bottom whole of the struts (front) to get good camber. The rears don't bolt rite up. I took a 3/8 drill bit and drilled a whole on the out side of the original top hat hole. The out back top hats have a wider hole pattern. Its just tin and really easy to drill. I then used 3/8 fender washers to back up the nut. I used camber bolts on the rear too. I didn't change the rear arm and I don't think I need to the wheel looks quite centered. This took about 4 hours. I did it rite in the drive way. Hardest part was un bolting the struts. I like the lift a lot. I really is a big change of stance and driving. I put bigger tires on too . My old struts had 250,000 on them and totaly blown up. the first out back, 95/96, struts aren't any different than the legacy no lift.
  3. today the light came on and said i have a bad starter switch. interesting...
  4. o2 sensor.. I drove 194 miles on a little over a half tank. wierd that the check engine light didn't let me know.
  5. well i got a check engine light that came and went I had a loose connection on my cpc solenoid. so i tightened that up and replaced the o2 sensor, I had one laying around. i didn't think about the tire size difference. I went to http://www.miata.net/garage/tirecalc.html and used there calculator. I can add 7.5% to my crap mileage. so that's up to 12 ish. i will have to run another tank through and see. I am going up the pass on Monday. We will see. I just did a tune up, in anticipation of a winter of rallying up the pass. I will have to check the brakes next. thanks very much for the help.
  6. hi i recently put outback stuts and bigger tires on my 92 legacy. I am getting 11 mpg combined mileage. that is not ok. I get 19 in my dodge diesel. do you think the blizzaks would effect it that much. my hope was a little more ground clearance, sometimes I beat the plows going up to stevens pass. The trip costs $20 now. Any suggestions? It drives realy nicely with the lift and tires. I thought power would be an issue. But its not. Any thing would be helpfull.
  7. i sold it today sorry.
  8. do you still have the transmission ect? thanks eric
  9. thanks very much,
    sjr is his company rite?
    thanks again
    eric
  10. Hi This is Jerry, i build a 5 speed kit to fit in the EA81 cars. Scott from Bellingham is the guy that builds the EJ to EA adaptures. If it was me i would use the EJ 5 speed for the street but for off road then the 5 speed dual range tranny. Thanks Jerry
  11. hey how much are the 5 spd adapters for ej conversion. i'm trying to wiegh all my options. i got a 5 spd legacy donor. and i was think about doing an entire conversion.
    thanks eric
  12. thanks everyone, i think i have gotten the nack for searching now. sorry for the redundant questions, noobie you know. thanks eric
  13. aaa is realy cheap too. $86 for 4 tows, the car has to be registered though. probably the best best. its easy.
  14. i got a truck, a dolly is about $50 from u haul. i can do it this week.
