Contact Methods
AIM
tysree@hotmail.com
MSN
tysree@hotmail.com
Location
Gresham
Interests
Car's
Occupation
None yet
Biography
I like to learn about cars and want to be a mechanic some day
Vehicles
1986 Subaru XT Turbo!
tysree's Achievements
Advanced Member (3/11)
0
Wondering about a few things. (Pics)
tysree replied to tysree's topic in Old Gen.: 80's GL/DL/XT/Loyales...
.....So is it the second picture? -
Well It did over heat and lost power, Nobody has told me what direction to go in, inorder of fixing this. I'm 17 and getting into cars this was a $280 fixer upper and I guess Ill be selling it for that now too. Sorry I dont know where the thermostat is. -
Just put on new head gaskets and I dont really care if the car is fast or not I just want a daily driver type of car that wont over heat. The only reason I got a front mount is cause there was a cheep one at u pull it. And Ive herd that the thermostat is in the radiator? -
What does this plug do? The little white one. Its coming out of the distributor. Dont know what this is either? Thermostat??? And this? The reason I'm posting these is because my engine has a cooling problem and I'm trying to figure out why?? Thanks for any suggestions Oh also wondering how to install a front mount intercooler? I have an intercooler just need to see how people have installed theres. Thanks
It's not in too bad of shape the body is strait, the paint is fair, it runs good except for the switch to the fuel pump everything in the interior is good but the dash that is the bad part. Has a boost gauge and it says im running 7 lbs of boost. Its gets up. ;D I wont ask him!
How much Is a good Price? 1986 Xt Turbo- $1000?
When ever I slow down really fast and go to turn my Xt's rpm's will drop and then eventually stall. This started happening after I got a whole new distributor but it was used. Should I just get a new cap and rotor the used one looks kinda bad. Thanks.
have you checked the power to all your injectors too? That's was one of my problems my car would start then die cause the plugs on the injectors were dirty. Just a suggestion.
I got the Right disty for my car and It has so much more power. Its a huge difference!
Okay cause I have a non turbo distributor and it works but is missing the 2 other wires that don't go to the coil. I don't know what those wires go to?
Well I messed with the wiring and I think it was getting a bad connection because it got warm today and the fan popped on to cool it off so Ill see if this problem is fixed tomorrow when I can drive the car :] Also on another note I was wondering if an ea82t in a wagon would have the same distributor as an XT turbo? Thanks
Im not positive but I think that hose gets warm. why would the water be boiling out of the overflow?
There is a switch for the fan? Is it on the fan side of the radiator I want to replace the thermostat too, my car is the same way some times it will run cool and some times it will run to where it wants to over heat. Then the water steams out of the over fill or reservoir what ever that it's called. thanks for the suggestions too!
I don't think my thermostat is working because the car gets really hot and some times the electric fan wont turn on? I don't know if that has to do with the thermostat? Should I just get a new thermostat?
Ground Wiring Question XT Turbo
I dont know what any of that is?
