Smpol19
Contact Methods
AIM
Smpol19
Location
Nothern, VA / Long Island
Smpol19's Achievements
USMB is life! (4/11)
10
Make sure the clutch is actually pushing the switch when it is up. There is a little tab on the top of the clutch pedal which is suposed to push the switch but it has a hole in it which should be covered by a little peice of rubber which falls off eaesily. A penney duct taped on this tab fixed it for me. Just something to check...
Sounds to me like he's talking about the 5 speed gear box, not the diff in an auto tranny. I know with the newer cars if you are going to use synthic about the only thing that works that's availble in the US is Redline 75w90NS, its got to be the NS because this is a GL4 oil. Redline, and mobile's normal 75w90 is a GL5 which doesn't get along with the syncros and leads to a lot of grinding. Mine takes just over 4 qt. I know this is true of the newer 5 speeds as I have learned from experience w/ mine and there are a ton of threds over on nasioc.com. I don't think much has changed since the gen 1 Legacy's but you may want to double check.
Is that quote from Stolhman's in Tyson's, their parts and labor prices are outragous. Sheey Subaru in Springfield is a little less I paid about $1,000 for timing belt, water pump, and tenninsioners abotu a year back. There are a few other decent independent shops in the area too. All this stuff is expensive in this area, noone around here knows anything about the work being done so they can get away with charging anything.
I've had 3 windshields in the last 5 years or so replaced by Safelite, last one was a couple weeks ago on my Impreza. Called at 8am on a Tuse. and it was replaced by 3 in the afternoon for $250 plus I finaly have 6 in. blue tint on the top that Subaru doesn't do for some reason. Anyway, I've heard bad stories about these guys, but they do a lot of windows and I've had a few decent enough experiences with them.
Possibly some air left in the cooling system. Easiest way to fill it is though the top hose first and then the raditor, this usualy keeps the air bubbles out. Its easy to get air traped in these cars though. Other then that maybe the water pump, but I don't see how you could route the belt so the engine runs and the water pump doesn't.
Auto or 5 speed? If its a 5 speed there is a little rubber pad at the top of the clutch pedal which is suposed to push in a switch to tell the car the clutch is out. This pad tends to fall off and is a hole in the metal plate and the switch doesn't get pushed. A little hard to explain but you'll get it when you see it. Anyway go up there and tape a peny onto the peice of metal on the clutch. This happened to me a few years back, I was looking all over then I came in searched the board and it was fized in 5 mins. Good luck.
The car I currently own appears to have been in a similar accident before I owned it. Everything is fine with it and i have 132,000 trouble free miles on it. The only problem is that there is a fair amount of wind noise at high speeds because I can't for the life of me get the glass to hit the gasket just right. So I would make sure to test drive it on the highway and make sure there is no bothersome noise before you buy.
