Gender
Not Telling
Location
Dallas, GA
Interests
40's-early 50's hotrods
Referral
Googled Subaru forums
Biography
wrenching on cars and electronics
Vehicles
97 Legacy Outback 5 speed
doc526's Achievements
Advanced Member (3/11)
0
When I started this ordeal a while back, the first question I wondered is how exactly does the computer determine a misfire. From what I have seen and read, the computer looks at the crank sensor and if it determines that the crank speed is different than what it is looking for, it throws the code. Some of the things I asked myself were what would cause a cylinder to slow down? My inital answer, poor ignition. Next questions was what parts are associated with that? Etc and go from there. I would start with the simple things first. Pull the plugs and check. Pull the crank sensor and check. I have heard about crud building up on the sensor causing them to drop the magnetic field that triggers them. Spray the coil with water. Check your timing. Since it is happening at idle it seems that it what ever is causing it is pretty severe. Then if you do start changing parts, go one at a time. This way you can be certain that you have actually fixed what was wrong. If I had not had an issue with a Hyundai I once owned, I would of called BS on the plug wire issue. I went through 4 sets of aftermarket wires before I returned them and bought OEM wires. Hope that helps. Dean
Here is the repair I did along with a write up. http://www.ultimatesubaru.org/forum/topic/109623-shifter-linkage-replacement/ From a wear stand point, I suppose the thing that the most damage would occur where there is metal to metal contact on the knucle where the bushings are worn out. Mine was rattling and being annoying so I changed it. Good luck. Dean
I have put the tone rings on and made them reasonalby tight with an allen wrench. You know, not Bruce Banner tight but nice and tight. On a second note, something I have not seen mentioned is that you might want to remove the ABS sensor from the knucke if possible. This way when you hit the stud with the hammer you don't impart severe shock to the sensor. Has any one done this without removing the sensor and not have any problems? Just curious. :cool: Good Luck! Dean
This is what you might be looking for. They are like a stripped screw removal tool. They will slip over the wheel lock and as you turn to get it off, they get a tighter grip. There are cheaper sets out there. This is what I happen to find quickly. http://www.grainger.com/Grainger/KENTOOL-Wheel-Lock-Remover-Kit-6ZAY9?gclid=CJL5ntfb-7ACFQ1T7AodPV3PdA&cm_mmc=PPC:GooglePLA-_-Fleet%20and%20Vehicle%20Maintenance-_-Automotive%20Mechanical-_-6ZAY9&ci_src=17588969&ci_sku=6ZAY9&ef_id=XgdP8fUlgVsAAFiW:20120702192317:s
1997 OBW 2.5 5Mt ~170,000 miles I had a stumble around 1600rpm while taking off from a stop. Been doing it for about 6 months. Did some reading and saw some suggestions on cleaning the MAF. So I took it out and hit it with some MAF cleaner. So far it has been 200 miles and it seems to have worked. Hope this helps Dean
How's the rest of the car holding up at its mileage and how are you planning on using the car normally are some of the things I would be looking at. Although you could always swap all the parts over to a newer car if you stayed in that model family. I considered swapping my mounts to group n until I read about the increased noise inthe cabin. My car is primarily used for everyday commuting and hauling the family around so that was not really desirable. Plus I don't plan on racing it anytime soon......
