Gene J
Contact Methods
Website URL
http://
Location
Wheaton, IL
Gene J's Achievements
USMB is life! (4/11)
10
My 98 had the hydraulics go out at about 105,000. Check to see if you have full travel. If they are bad it is more likely that the clutch would not disengauge rather than slip. The clutch is the weak spot on the manual Subaru's If you start out in second and floor it it will slip even when new My drive train guy did not have any HD clutch he would recommend. So he used one from the OEM manufacturer.
JDM headlamps
Gene J replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
So are there a lot of blinded Japanese folks? Please explain. -
After having finally gotten used to having ABS I would not like to drive without it. A case in point. When the tone ring on my Legacy was broken the ABS shut itself off in about a minute or so after starting the car. The practical difference? The wheels would lock up almost always. The real down side? If one wheel caught traction on a dry spot and the other three wheels were still on glare ice, the car could get sideways. Just drive more slowly and take your time. The ABS is just there to help you. Also for the record there is very little additional distance in stopping on ice with ABS engaged.
My 98 GT starter sometimes makes no noise when U turn the key. Not even a click. When the starter does turn it is just fine. A search revealed that it may be the starter contacts. Do the experts here concur? I need to know because it VERY cold outside where I will have to do the work. Why don't these things happen in the summer?
Ordinarily that is what I would do like when I remove an engine.. However I disconnected a few other hoses to get the that coolant hose and got in too deep. Does anyone else have a 1998 EJ 25 that can take a look? The questions are where do the hoses go from the air box and where do the hoses go from the T that connects to the block. Thanks!
