Vanislru
About Vanislru
- Birthday 04/26/1978
Contact Methods
Website URL
http://
Location
Cumberland, BC
Interests
Backcountry skiing mtb.ing
Occupation
Electrical Contractor
Ezboard Name
Can't remember.
Biography
Subie lover since '94
Vehicles
86twagon 91legacy ej22t
Vanislru's Achievements
Subaru Nut (7/11)
10
Poll: High compression turbo life
Vanislru replied to kingbobdole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well over a year on my high comp turbo ea82, and alot of that is abusive 4 wheeling pushing 29" tires around. -
I hooked both turbo's up to my electric leaf blowers exhaust and then measured the air flow each turbo generated. The Td04 moved way more air and spooled quicker. Much better turbine. If only I could find the time to swap it on.
Not worried about the turbo itself, if it's really hot the snailshell on the hotside might crack at the worst. BUT if there's any stress on the header and it's really hot and then submerged it could crack at the flange to the turbo. Happened once to me but my exhaust was all fubared from sliding on it. The stainless TWE header and DP are solid and show no signs of fatigue. Get a parts car, or 3 heh, that's my advice.
Pics of my 4 " lifted turbo wagon, more in the user gallery.Do it, turbo's are great offroad, no exhaust header in the way and the extra power helps on the way to the trails.
It's probly OK. On my way back from a surf trip I started to hear a knock. It got worse, much worse. With all my gear in the car there was no way I was leaving it on the side of the road. The last 20 km to my house I was on 3 cylinders with a horrible racket. A piston and connecting rod had been at each other for over a 150 km's! that's about a 100 miles. After swapping the motor out I took the oil pan off and what a mess. LARGE junks of Al. everywhere, pickup strainer was mostly clogged but the oil filter wasn't too bad. The turbo was/is fine, and I know this motor was chewing metal alot longer than 100 miles or so. Long story I know but a happy ending for the turbo. Probly for yours too.
Yeah, I think that's why it's so popular to swap the Td04 or similar (mitsu?) turbo's at the same time with their 90 degree rotated outlet's.
boost and high compression EA82....
Vanislru replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Uhm well I was going to PM you a response but hey I love a bit drama.. Take another look at that post, like I said I'm not about to go an dyno my subies just for the sake of telling others what #'s I had on such and such date. I'll take that money and spend it on my kids thanks. I was pointing out that to "tune" a car doesn't mean you need a dyno and that there is a difference between a #'s run and "tuning" in more than just dollars. Understand? I have no clue? don't diss? werd... . -
I take mine up to 7500 rpm fairly often, #'s? I'd estimate a realistic 180chp tho I'm sure it'd dyno a bit higher... Caboobaru are you sure you need the nissan injectors? I really need a DP for my TD04 I see WJM has a stromung for sale but it's got a divorced wastegate and I want a bellmouth. Volume is where it's at. -
I've spent a fair bit of money on my subies over the years, my legacy ej22t w/mods is pretty damn fast. Personally I think the posts talking about dyno's and tuning have come off sounding like you have little experience with "tuning". Sure I can head down island and dyno my car, hook up the wide band and tune it for whatever the desired result may be but the bottom line is if you have experience and don't care to have #'s to talk about it's not needed. If I dyno'd every car every time I did a mod I'd be broke. I can tell whether I'm rich, lean, or stoich.. That's mostly what you'll get for couple hun. buck around here, oh yeah and bragging #'s. "Tuning" costs alot more than a $150 bucks or so. What are they going to "tune " on my car? Do you know much about our flashed CPU's, or the engine management system? Not much there to "tune" really. Personally I don't want any of the local dyno shop's advice/oppinion, if I did I'd pick up a subscription to Sport Compact or some other glossy crap. My subies are fast sure, but none of them could hold a candle to my old 69 firebird (RIP). EVER. It wasn't meant to turn well or stop but if you've ever honked on a late 60's "strip" car you know that's not needed for thrills. HHmm big block V8 of thunder aahhhh:slobber:
Well said. My ea82t wagon was fast until it got lifted with big tires. Until that it broke loose in third gear at 3000 rpm @15psi. Lots of pull all the way up to 7.5k most likely had similar #'s to WJM. Motor had recent top end rebuild, has oil cooler, TMIC (large core AUDI F.M.I.C.) with well laid out pipeing, higher fuel pressure ~40 psi @idle, TWE Header and DP w 2.5" to the back no cats, ported turbo on the hot side for higher flow, and now runs with a 9.5:1 comp ratio. Too bad it's spinning 29x10.5" tires now:/
I take mine up to 12 psi WOT sometimes more. SPFI block TMIC 86 computer and maf. Run it rich. Don't bother with the port and polish, make sure the intercoolers pipes are smooth tho nice transitions and corners. Stock engine management with fuel pressure around 40psi or so with AFPR. This will give you what you want while still maintaining as much stock equip. as possible which will save you much time and headaches. If it gets a bit wierd at higher fuel pressures consider running without the O2 sensor connected. Spend the money on the good bellmouth DP and exhaust and a good TMIC setup, help it breathe. -
I have them but haven't been able to install them yet, moved twice and pregnancy complication have kinda gotten in the way. I'm contracting, stand in mom, dad, pretty much WOT right now. Oh yeah work too. I cringe whenever I look at the D/R in the shop, timing can be a real ***************
Progress!? ah well... Rianna's on bed rest with our 2nd babe right now and I've been hella busy with electrical contracting so not much progress. With any luck I'll have some results by the end of aug. aybe sooner but with the way things are going who knows? Hell I haven't even been out for a quick wheel in almost a month now :/
Please help diagnose my friends dead twagon
Vanislru replied to Vanislru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Motor turns over well, starter is fine. No spark tho today so that's the direction I'm looking to right now.
