smotocon1
Contact Methods
  • Website URL
    http://www.eseephoto.com/album.php
  • Location
    Washington
  • Ezboard Name
    smotocon
smotocon1's Achievements
Advanced Member
Advanced Member (3/11)
10
  1. I'm looking at a 90-91 legacy L AWD sedan with a auto tranny. It will not go in reverse. is there a governer that can be cleaned like on the older GL models? What could it be? It goes forward fine in all gears.
  2. I have found a about two-hundred subarus all 90 and older. I've been driving buy this place for the last 5 years and finally stopped Its on your way to Anacortes Washington. If you have ever driven up there Its right before the Chevy dealer on the left up on the hill side. Here is a taste of what he has. 6 gen 1 brats 4 gen 2 brats 5 XT4 most with turbo 0 xt6 lots of wagons lots of sedans didn't ask if there was a RX or not sorry He will sell the whole car and do some parting out but I figure that two or more people could buy one car and get what they need for alot less than individual prices. He's not in the phonebook as far as I have ever seen so here is the info. And tell him Ian Sent you. see if he even remembers. E&B Salvage/Parts (360) 293-7797
  3. Will a Xt 4x4 4spd auto tranny bolt up in place of a 4x4 3spd auto in a GL-10 sedan? Will I need the driveline? Will the pistol auto shifter fit? any info would help. thanks, Ian Shastko
  4. Is the XT6 fuel pump higher flow than the turbo model? is it external or internal? I'm looking to upgrade any help please let me know if anyone knows. Thanks, Ian Shastko
  5. yep! it is! here is a breakdown of what I used and its really a drop in fit too 1- saab long 2" O.D. aluminium intercooler pipe with funky 90 deg. bend 1- cast aluminium 90 deg 2.5" O.D. elbow 1- 2" I.D. 90 deg intercooler hose 3- 2.5" I.D. x 3" intercooler hose 1- SVO mustang/t-bird intercooler 1- 2" I.D. x 3" intercooler hose 1- 2.5" O.D. x 4" aluminium intercooler pipe as far as the BOV I have access to a machine shop and it only would cost about 20 bucks for someone to do a surfasemount like mine. All items were purchased off of EBAY for really cheap. I still doing a mounting bracket for it but its not going anywhere. If there are any questions just ask.
  6. The Blow off valve is to atmosphere. The HKS super AFR has a electric idle stabalizer to compensate for it. Its COOOL! whoooosh!
  7. Just installed my intercooler setup with HKS BOV, HKS EVC boost controller, HKS turbo timer, HKS super AFR, Air/fuel gauge, Boost gauge. Next is the hood scoop! http://eseephoto.com/album.php?albumid=dc7092e13614661d0a50&1083801420 Login: legacyt password: monty
  8. Trying to findout what filter to use in my car. My car is a 87 GL-10(turbo). The K&N sight has no real selection for the turbo motor. yet there are two part numbers. One for the RX (P/N:33-2232) witch I would think woud be the same as my turbo sedan and one for a 1.8L F.I engine (P/N:33-2010). Does anyone know?
  9. I was lucky to pick this one up for $150. I was originally on ebay but sence the guy ended up living two blocks away he ended it early and gave me a good deal. Thanks to by the way. I will be installing an older apexi afc-r could you give me any info to make the install easier?
  10. I need the following locations on a 87 turbo ECU: -RPM and or injector signal -ECU ground -throttle position -speed signal -ECU 12v power
  11. Not sure. I think subarutex has one of those installed. But a AfC is differant than a AVC. The AFC stand for Air Flow Converter and is used for air/fuel managment. AVC stands for actuator Valve controller and is used for boost controll.
  12. Installing a APEXi super AVC-R and was wondering if you guy had any diagrams that show pin location for the stock ECU. Anythin would be a great help thanks
  13. Whats going on with the group buy? I need to get my car on the road. Will they do one off's? Could someone give me some contact information? I don't mean to step on toes but I wasn't joking when I said I wanted and needed the parts. I need to know if I need to look for another sorce or not. Update?
