bergle
Location
austin
Vehicles
I Love My Subaru
bergle's Achievements
Member (2/11)
0
Hey all, I have a 95 Legacy Wagon that will start and run for about 10 seconds then it dies. It will stay running if you squirt starter fluid in the breather, but obviously that doesn't indicate the real problem. I replaced the fuel pump and filter. I really think that this is an electronic (sensor) issue. If I bought a code reader would it tell me which sensor was bad? Any other ideas would be appreciated too. thanks-
Howdy all ! I have a 1993 Legacy that is really sluggish lately. It is very slow to climb hills and accelerate on the oped road. I tried changing the wires and plugs as well as fuel filter, transmission filter and oil. There is no Check Engine light on either. Any thoughts on what could be causing this.
Hey friends, I am in the process of changing the transmission fluid and filter in my 1993 legacy wagon because the car was getting kind of sluggish shifting and driving. While I have it apart are there any adjustments underneath that I should make to tighten it up? Also what is the proper way to refill it? thanks a bunch. Any other tips would also be appreciated. -)
The front end of my 93 legacy wagon seems to be loose. It is quite scary when driving at high speeds and it meanders across the road on its own. I was told that it needs new rubber bushings, but I don't know what to order, or call them. Any thoughts? Also, if you don't think that's the problem let me know that too. thanks-
OK, so my 1995 Legacy has had the check engine light on for a while and it started to run really horribly. Then after the cold snap we had, it would only start and run for a few seconds, then die. It will do this as many times as you care to start it. You can keep it running by squirting fuel directly into the intake area, but short of that it won't stay running. I changed the fuel filter and that did nothing. The fuel pump seems fine as well. I'm pretty sure its a sensor issue, but which one? Any thoughts? Bear in mind the car is immobile right now. thanks-
