Mickey Maz
Everything posted by Mickey Maz
  1. my 2004 outback 2.5l engine needs timing belt changed and the hoses replaced. my mechanic will replace water pump and use subaru parts. there is a slow oil leak from head gasket. i would like to just have him do the timing belt/hose work and leave the head gasket as i read that they can just have slow oil leaks for several thousand miles..by that time i may replace the car. the timing belt work would take a few hours and if i have the head gasket done i am without a car for a few days. has anyone had any experience doing this? any ideas on waiting? thanks
  2. I have a 2004 Outback Wagon. A few years ago I developed some of the same symptoms you have. My dog refused to get into the car. I went out and bought a carbon monoxide detector..started the car and put on the heater with windows closed and did not get into vehicle..sure enough the alarm went off. I suggest you do the same to see if that is what is happening..you have a lot of the symptoms..and it will kill you. It corrected itself after a while...my brother said it sounded like some valve was probably stuck in the open position
  3. Carbon monoxide is getting into car from the heater system as best I can determine. I had Subaru dealer check and they can't figure it out..plus I had a local mechanic look at car. Both checked exhaust system for leaks..none. There are no codes showing. With the air circulation on or the air conditioner it seems OK. I was feeling sick when in the car so I put a carbon monoxide detector on front seat with heater blower on and the alarm went off. Anyone have any ideas??
