4
Everything posted by AKghandi
ea82t wont stay running
AKghandi replied to subarurx yo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmmm. So that's not your problem. Mine does that with the Maf hooked up. -
i usually just unhook the battery for a few minutes. also check the wires to the cts and the connector mine the wires were frayed and the plug in was corroded. as soon as it was fixed the CEL went away immediately also does it run better with the maf unhooked?. -
the cts is right next to the turbo its a 19mm with a 2 prong connector sticking right out of the coolant passage -
hmm.. well if you get it figured out let me know, im goin crazy with this dam thing. -
you know i think it might be the hg. not it the traditional oil in the water kinda way but in the one cylinder leaking into another.. because when it back fires the turbo light comes on for a moment. . and when i pulled one of the spark plugs on the passenger side it wouldnt even start...which means problems because ive seen these run with just the drivers side timing belt.
i know the feeling man. mines doing the exact same thing.... did you use crc maf cleaner? because thats what i used right before this all started.. and i also have the 20 dollar ebay mbc. -
Yeah i thought about that too but it's getting too much air which exPlains the bad idle and the lack of power under boost and since this all started while I was in boost. I'm going to be getting a pretty big tax return so if it isn't fixed by then I'm going to buy New car. something simpler like a ea81 or a legacy. In other news I think my turbo is going down the drain due to the metal shaving paste in the turbo outlet. So that's always fun to deal with.
87 gl-10 ea82t you have the exact same problem i do. does it backfire? and bog down?. revs like crap and barely drivable? is crazy how you have the exact same problem. you should look at my thread.. help oh subaru gurus in dire need of assistance. ive narrowed it down to the intake gasket but im still not sure thats the problem maybe we can help each other out mine started after i turned the boost up a lil bit which is why im leaning tward intake gasket -
well i bought a new coolant temp sensor yesterday i put it in and the cel was off. the car wasn't running any differently tho. then i changed the alternator back to the one the car had originally and now the cel is on again with the same code. i hate problems like this because once i figure it out im going to kick myself for not figuring it out sooner. its something simple. its one part or something causing this. i just gotta figure it out. But on a better note ill have some cash today and a garage to work in(thank god!) so hopefully ill get it figured out by the end of the day. yeah ive been meaning to buy a voltmeter but i kept getting sidetrack with other projects. like my perfectly running 84 hatchie with a bad clutch cable..both cars broke at the same time. and no one in alaska seems to have the cable.
I wish I had 10 bucks. But I wont have any cash till tomorrow, so i get to just look at things. But as soon as I can I will definitely do that. Here in a few minutes ill go out and check for anything obvious.. maybe a wire cracked when i was moving things around. I do have a test light so i can check to see if its getting power
well.. i don't have any kind of troubleshooting tools so i just unhooked the return line to make sure it was at least letting fuel out(quite alot of it) and i also checked the return to make sure it wasn't clogged. havent checked the vacuum line to it yet. yeah its definitely running rich. really rich which makes me think it might be the coolant temp sensor system, because that's the only code its showing. ill head out in a few and check the wires to see if they're crossed or grounding somewhere and while im out there i might as well clean the plugs and back blow the fuel filter. i should have a little money tomorrow so if all goes well i can go out to the subie grave yard and snag all the sensors off one of our fallen friends
Drove it to drop my brother off at work it's now on the side of the road. M**********r and the walk in the snow was fun too. So now I'm thinking it might be the exhaust something is getting very hot and making a smell I don't recognize it's not the cats because well I don't have any.ill unbolt it when I get the car home see if that makes a difference but I doubt it will.. I think this car just doesn't want to run anymore.
Update! I put the alternator back to the way it was and now I can almost drive it. It spools up and gives all the power she had before but it revs up like crap, like before. Although notably the backfires have stopped. And now the cel is on showing code 21 again which makes no sense because I just replaced the CTS and it wasn't showing that code before I swapped out the alternator... Ow. My brain hurts..
ea82 loyale blown headgasket?
AKghandi replied to Prwa101's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's recommended to replace the head bolts but if they torque to spec they should be fine. Also does the car still run? If it got that hot I'd worry about cracked heads( make sure you loosen the head bolts slowly in a crisscross pattern to keep from warping/cracking them.) also I've seen cars that were overheated a couple times and the piston2 and4 had large holes in them( when I poured oil into the cylinder for a compression check and I just heard I drain right into the crankcase. That was on a dodge shadow tho. Sucked too because it had 65k miles and I bought it from the orig owner. If I had the money I woulda fixed it. Sorry to ramble like this but. I know what it's like to tackle a job like this and on a Subaru it's even harder. ( world easiest HG? Dodge 2.2/2.5) I love those motors lol:headbang: -
Yeah it doesn't have any codes ( In u check mode) haven't tried the other modes. I'll check the injectors in a few minutes. I can't remember if this is correct but doesnt the. Alternator have something to do with the fuel pump? Bad voltage regulator giving it too much fuel maybe. This did all start after I replaced the alternator..
If you search for post apocalyptic head resurfacing techniques or something like that. I think it was GD who posted it, could help you save a few bucks with the resurfacing. -
Yeah I get that a lot but my current gl-10 is an 87 lol sorry for any confusion And right before this all started I cleaned the Maf with crc Maf cleaner it was running perfect better than it has ever run then it just started doing this again And when I put the Maf back after cleaning it all the hot/cold wires were intact.
Yeah I need to buy a voltmeter so I can check the resistance I actually have several repair books and a fsm for my car. What do you mean " flap"? This is the first I've heard of this I know my car uses a hot wire and a cold wire system in the Maf if you have a picture of what your talking about it would make figuring it out much simpler if not I guess I'll just burry my head in a Haynes or chilton manual till I figure it out
Yep you got a headgasket problem. I recomend crc headgasket repair it's pretty amazing stuff and I've seen it last quite a while But if you want to fix it instead, pulling the motor is the way to go milesfox has quite a few videos on YouTube "the art of Subaru maintenance " that series will help you a lot. He doesn't do the headgaskets in the series but the motor pull procedures and the engine reseal is all very good info. You may also consider having the heads resurfaced. Just so you don't get it apart and back together just to have it leak again. Edit/ lol well looks like I was beaten to it .... Stupid itouch. Lol
