gwilson87
Everything posted by gwilson87
  1. Just give up now and know that your legacy won't be as cool as my brat. Nothing personal its just a fact... sorry.
  2. Yeah pilot bearing was replaced the same time i resurfaced the flywheel. It was still feeling good when we pulled the engine to change the clutch.
  3. Flywheel was just barely machined and still looks really good. Feels like chatter, sounds like chatter, but its only at the beginning of driving. I will have to hit some hills and see what it does. One my previous clutch, it slipped a lot when accelerating up hills.
  4. Input shaft was fine, new throwout bearing, fancy new subaru TB clips (last two the local dealership had) and greased fork. The fork was greased as well where it meets the TB. It shakes REALLY bad in first and second at start. I know it sounds like I just suck at driving a manual, but its after It is fully in gear, and I am moving. Shakes around 10mph, and then shift to second is fine, I can move forward and then from 15-19mph it does that crazy shaking as well. The car is awd, and I am starting to scare myself into thinking the transmission is screwed up. Maybe I will have time monday to do some more hunting.
  5. FML New Exedy clutch, same exact symptoms. Now I have a cold, and am going to eat some soup and pretend I didn't just waste two days in the garage catching the cold... Axle, hub, wheel bearings? It shakes too much to feel confident in sitting it on jack stands and "driving".
  6. Been awhile but finally got the knock sensor replaced. Car seems to be a bit more nippy around town (at least until the clutch, I think crapped on me... another story) But on the uphills in 5th it still bogs down. Went on a trip for work today and I was cruising the freeways fine, headed up a canyon and was accelerating and once i shifted to 5th it was like the car decided 60 was as fast as it would go regardless of how far my foot was in the floorboards. 4th gear gets me up just fine at 70 with the rpms at about 4500. This is with relatively new plugs also. Any thoughts about this? I long for how it was when I bought it, somehow doing 90 uphill...
  7. Just got back from Autozone, my buddy was working so I got my money back easily enough. Now to find who sells exedy locally. I really don't have the time to wait for one to come in the mail. Actually I might....
  8. Well I don't have any friends. Well at least any that are available. Here is the latest. Whilst driving around for work today the car was doing pretty fine. Slight rattle but nothing really noticeable. However, after a quick stop, it started to slip really bad in first and second gear. Kind of odd, basically anything under 20 miles per hour once the clutch was fully engaged. REALLY sucked coming home in rush hour freeway stop and go. The slip wasn't so much of a slip as a chatter/ shake my entire car REALLY bad. The engine is pulled and the clutch is off and seems fine (it only took an hour and I can go into autozone and get a new one under warranty no questions) But I kind of want to see if I can just get money back and go buy something better than autozone cheap-o. Any suggestions now? btw, the clutch disc seems slightly glazed at the edge but nothing too much. The flywheel is still in good condition it seems, just had it resurfaced with the last change. I kind of wonder if maybe the pressure plate isn't strong enough with it being the cheap autozone one. Bleh, I just need to buy a new car...
  9. Clutch fingers are fine, I checked those first. I guess I will pull the engine saturday and see whats up. I will provide info as it shows up.
  10. Yeah I think if it was within the transmission, it would have to be pretty bad to make that noise heard on the outside of the trans. Also I think it would be a more consistant thing. Maybe I will pull the engine this weekend and just replace the clutch, gotta love autozone warranties.
  11. Ok so it isn't doing it tonight as I drove down to visit some friends. It did a sorta clang if while driving, I let off the gas a bit, and then push it back in it would clang as the engine put its power on the wheels again. Fairtax, it was doing it most when I was in gear coasting to a stop, then when I pushed the pedal in, it carried on for a second before stopping. Once or twice, it would do it even with the clutch pedal in and coasting to a stop. And so far, in gear or not hasn't changed the noise at all, haven't tried it with the car off. Nipper, I don;t feel any vibrations in the clutch pedal actually which was kind of odd I thought for the type of noise. Also slowing down with the car in gear used to make the noise and it would leave once i pressed in the clutch. On my last clutch it was making this noise pretty regularly and only when i was moving in gear without putting on the gas. But the new clutch got rid of it. It is not effecting driveability other than being bothersome and making me think something is about to snap. But as I said, for some reason it isn't making the noise as much since this afternoons trip to the junkyard... maybe it healed itself?
  12. ok here is a link to the youtube movie. The rattle is most apparent at the annotated parts. Today its making it when the clutch is pushed in mostly, and when slowing down. Maybe brakes are screwed up? I dunno...
  13. Yes the spring is there. and the cable isnt so tight that its always touching, i will check the freeplay in the morning. But I think its pretty close to 1/2". Thanks for the replies. The more info I can get the better.
  14. Its not heat shields, the mounts all look good, and exhaust is sturdy. The only way to describe the sound is like whenever I let off the gas a bit in gear, it sounds like something is bouncing around almost in between the pressure plate and flywheel. its more of a sharp higher pitch pinging. And its only when moving. I tightened up the clutch cable and I'm going to drive it around tomorrow and try to get some audio of the sound. My preference is definitely to not pull the engine (as fun as that is). Hopefully that helps, if not then I will try for video in the morning and just hope the car gnomes show up and fix the car while I sleep
  15. Ok lets hope this can make sense. Did the clutch less than 2k ago and just barely did the knock sensor (doesn't pertain, just happy that I finally replaced it after a year of having a CEL). Anywho, in the past two days I have started to get a clanging type of rattle sound. I once had the same sound but it went away when I replaced the clutch. It usually happened when I am in gear driving and let off the gas some to slow down, and when I would push the clutch in, it would go away. Now it happens sometimes even with the clutch depressed, and it will slow down as I come to a stop. Keep in mind this is not constant occurrence just sporadic. I checked adn the clips holding the release bearing are still on, the flywheel fins look a tad worn (color wise) on the edge where they contact the bearing. Now my questions, What could possibly be causing this issue? And how to fix it? I am planning on pulling the motor, again, tomorrow and would LOVE if someone has had this problem and knew a fix that didn't involve getting a new clutch. Thanks in advance.
  16. This is fun, when I get back in school in january I am going to try and start designing a pre-runner brat. Only problem I can see is it would only be rwd so that the front can have its totally awesome travel. There is my two cents, now the big boys can carry on.
  17. I got my fuel pump from an older legacy and altered the mounting plate so it was in the same place. The pitch stopper I still haven't installed mine and haven't had any noticeable trouble. Others have never put one in I know. I'm sure a smarter person will come along and give more detailed info.
  18. :slobber: :slobber: nothing more than eye candy to me, no way on earth the wife would let me have another brat.
  19. Mmm... Dirt jumping and riding in moab... If I only had the money. Hopefully everything works well and the sub gets some moab action.
  20. yeah the one under the dash is what im wanting to experiment with. Are you willing to just give it up for free? :D Either way, give me a text or call when I could come get it. 801.376.8490 Glenn
  21. If the spacing on the holes in 6.5 inches (from one side to the other) then yes they should fit. Or you could just pound out 2 studs on your hub and see if the wheels fit
  22. So did you already ditch the car you used for your engine swap? If not I was hoping to snag the fuse block out of it. I want to run a secondary fuse block for things such as lights, cb, ham radio, more lights, etc.
  23. So when are you going? I'm wondering if the brat has the gumption to make it to moab... Me and the wife want to get out there for some biking. Maybe we could find some people and get a lil subaru group out there.
