kd7dej
Everything posted by kd7dej
*Bump. So is ECS the only company out there doing complete swaps?
Well what prompted me to write this post was I have some money saved up and I'm starting to build my dream subaru. Looking to do a lift. So who out there does lifts? I prefer suspension lift. Found a guy in Washington, but his 4" lift is 3" of body and 1" of suspension lift. MIght need a little custom fabrication? It is a 98 Legacy GT Wagon. Shipping it off soon to Conneticut for some swap work and want to get it lifted when it gets back.
I have read whole lot about East Coast swappers and sounds like a great outfit to use if you're going to pay somebody to do swaps. Does anybody know of an outfit on the west coast that is just as reputable and that can do the same type of work?I live in Oregon.
Was looking to get a hold of John in Eugene Oregon, but looks like he was banned? Anybody know how to get a hold of him or if he is under a different user name on here? Thanks Bill
Ball joint help
kd7dej replied to kd7dej's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Nevermind, walked away shortly before I did this post and approached it again today. Done and fixed. Just cleaned out the socket real good then made sure I used a good wedge in the pinch for the housing. Managed to get it right in when I used the wedge. -
I have a 1996 Legacy Wagon. I had to replace the front axle on the drivers side and the tie rod boot. While moving things out of the way I saw the ball joint rubber was all crack up so I removed the old ball joint. Now I am trying to get the new ball joint back in the knuckle. It will not seat all the way, and at this point would probably be difficult to remove without buggering it up. I have the ball joint bolted into the control arm and have tried using a jack on the control arm to push it in (both with and without the swingarm bolted up), the pinch/housing deal I have spread with a bar and so on, but that sucker will not pop back in. Any advice or places to send me too? I am a visual person so a write up with pics would work well. Thanks
Why not? If it is a reputable shop that you are familiar with? They back their work so any problems that come up they will fix? and you have the financial resources to do it? Between me and a few friends we could probably knock it out, but sounds like a pain in the rump roast so why not pay someone? Because god knows there are not any people out there who want odd ball cars, or any car for that manner, tricked out and pay someone else to do it for them? Not everyone is in it for the satisfaction of doing it themselves, some people just want the tricked out car and don't mind paying someone else!
I think I will be staying away from that motor and maybe look into the EJ20T. There is one that is a JDM available to me locally. I remember reading around that EJ to EJ swaps are pretty easy and swapping from an EJ to an EJ turbo does require more modification cause of the ecu and wiring. I know it would be easier to just get a turbo car, but that is not the point. This is my project car and I have already done a ton of work to the aesthetics and now am checking into the performance. I also found a local subaru shop that is very experienced in doing subaru motor swaps. I did speak with them about putting a modern day STI motor (EJ255 or EJ257) in the car and it really wouldn't be that expensive to just pay them to do it for me. So if I get the cash I probably will be making this project happen.
I change them at every oil change. I've ran them in lots of off road vehicles around gobs of dust, and have never had any problems as long as I have kept them oiled and clean. Never have though twice about it. As far as dust with the filters, that is why you keep them oiled, the oil is supposed to trap the dust, while the filter catches the other particulates and allows more air to flow, at least that is my understanding? Paying for oil and cleaner is not much of a problem because I have several bottle of the stuff I have accumulated over the years from my other vehicle and toys. I guess everyone has their preferences and K&N filters are not a preference for many users here. So any answer on my EJ22T question with the ECU and wiring? Don't wan this post to get too side tracked with arguing about pros and cons of K&N filters?
Well I don't think the K&N is for some drastic improvements. They do have better air flow than the regular old paper filter. I've never heard of a K&N doing anything bad to your motor? I look at it as more of a benefit of having a filter that will last for years and years instead of buying a new one at ten bucks a pop every few months. I'll be calling Delta cam soon. I think I want to 'advance' my cam so that I can get more low and mid range torque after researching it a little bit.
I'll check into the cams. I am definitely not going to do anything with the air going into the motor, and just picked up a K&N filter for it, that will be the extent of my breath in. Still debating about the exhaust though. I've put a lot of exhaust on cars in the past and did seem to make a difference. So the EJ22T? That pretty much a straight swap from the regular EJ22? Wiring harnesses need any mods? Need to make sure I get one with an ECU because I am assuming the regular EJ22 ECU will be no bueno?
Well I just cut off a lot of my heat shield and found it to be the rear cat cover, Just did a quick tack weld, and wool-ah. No more rattle. I go out into the woods a lot so wanted to get the shields I cut off replaced, but I don't think it will be an issue so probably not going to replace what I cut off. Wanted to keep the shields around the cats so that they stay nice and hot to burn that extra fuel.
I have a 1996 wagon with a 2.2 in it that I am fixing up. Already did all the body work, paint, window tinting, fixing the interior, tore off that crappy stock roof rack and put on a yakima track system. Now I have been contemplating the motor. I would like to get better performance but cannot seem to find a whole lot of aftermarket parts out there. To start off I was thinking air getting into the motor and out. After a little research I don't think and aftermarket Cold Air Intake or other air intake is the answer since this car has one built in already, just probably put in a better air filter? Opinions on this? Second off is the exhaust. I think getting a high flow muffler and cats should not present any problems, but I was contemplating headers too. My concern is this, if I added a header, that obviously means more heat, which means potential problems with the oxygen sensor? I am concerned if I installed a header I could get the engine light turned on from this? Has anybody had success on installing a header without this problem and I do know they make offsets for cats to move the O2 sensor a little further away to combat this? Also does anybody know about aftermarket throttle bodies or injectors for this motor? That increase performance and are not just OEM replacements? Also is there any aftermarket cams, heads, etc? thanks for your help
Does anybody know if the exhaust heat shielding from a late 90's 2.5 motor exhaust system will fit on a 2.2 motor's exhaust system. I know the ports are a little different, but at a glance the pips looked shaped and ran the same? Need to replace my dented and rattling shielding and know a guy with some from a 2.5 legacy and mine is a 2.2 Thanks ahead of time.
Don't know if you ever solved this problem or not. I had the same thing, everything was tight, out of frustration I replaced the top mount strut bearings, noise still continued. After a while a checked everything very thoroughly. Turned out the boots were loose above the bump stop and were moving up and down. Did some playing around with them, got them tight, and no more noise.
So do all EJ20's have at least one turbo? I just have an extra Legacy sitting around, looks good, runs good, but have time on my hands.
I was just looking around the different forums on this site and others. I have dreams, but they are just dreams and will never probably happen. I have a 1996 Legacy Wagon! I was wondering if anybody has ever but a EJ257 into one of these? Also I was drooling at the EJ20T motor which is the single turbo motor outside the US? Then I saw a post of someone who said there is no EJ20T motor, just and EJ20G and EJ20(some other letter) and put one of those in a legacy? Just curious........? Thanks. Of course if you had the money to do these mods I don't see why you wouldn't just buy a WRX STI, unless you wanted the cargo space of the wagon?
