5
Everything posted by Datsunrides
Early 80's Subaru Head - Identification
Datsunrides replied to alohadogg's topic in Historic Subaru Forum: 50's thru 70's
Well, I hope they don't, but if something happens, I do have an extra set. mark -
I thought you had found a set of heads, or are you looking for spares? Mark -
Documented: The 1970 FF-1 Project car...
Datsunrides replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
I see no reason it won't. Mark -
To really simplify it, run the supply line direct to the carb. If there is any doubt of the pressure the fuel pump you end up using, install a regulator. Most carbs do not require any more than 2-3 psi. I would remove all the return plumbing and evap cans and cap off the fittings at the tank. Keep the filler vent. The key to this is using a vented gas cap, or the tank will build pressure untill something gives. Not a good thing. If your cap is not vented, or you can't find one, simply drill a small hole (1/16th or so) in the highest part of the cap and your set. Keep up the nice work! Mark -
just pick up the GF hard top
Datsunrides replied to maudsland's topic in Historic Subaru Forum: 50's thru 70's
I like it! Mark -
How to check CV joint
Datsunrides replied to oleman77's topic in Historic Subaru Forum: 50's thru 70's
Do a full lock turn both left and right. If you hear no clicking, your joints are probably good. Mark -
No oil pressure, need advice
Probably a combination of worn bearings and oil pump. I take it the oil is in good shape, not gassy smelling. The oil pumps can be had relatively cheap and are easy to change if other things look good. Mark -
Need early 70s 80s parts???
Datsunrides replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's
Where's the early 70's stuff? Mark -
radiator for 1975 subaru dl wagon
Datsunrides replied to subaholic79's topic in Historic Subaru Forum: 50's thru 70's
If you can't find a new one, and you still have your old one, you can get it recored fairly inexpensively. You would end up with a basically new radiator. Mark -
If you could swing it, I'd say a nice vintage wood rim Nardi. That Grant does not look bad though. Mark -
Good point on the connectors. I didn't want to go too indepth about every nuance. *IF* I were to be looking at something like this, I would find a lifter that had the closest dimension to the stock lifter, in terms of length + the additional length for the connector. Because the lifter would likely come from an american pushrod engine, the diameter would most likely be larger. You would have to line bore/gun drill the case and install bushings to make these work, if the case can even be drilled. By the way, I didn't think the EA71 came with hydraulic lifters? If it didn't, you would have to run solid roller lifters as the case would not be drilled for hydraulic ones. Then, you are still stuck with having to get a cam ground for a roller lifter. I have a feeling your being generous thinking 2 or 3 people would want them. Too much other work would need to be done to justify (In my mind) the extreme cost associated with this conversion, which would add even more costs. I would actually be much cheaper to turbo/standalone EFI the motor, than try and do the roller setup. and you would end up, most likely, with more power. Now, I have never been one to let a crazy idea stand in the way of me spending way too much money on an idea that has a more cost effective solution, just for the point of being "different". So basically, I'm just sayin'..........
Beautiful! Love the wheels!:cool:
As with most anything, if you gots the $$$$, someone can make it for you. You need to determine if you are just . To use roller lifters, you kinda need a roller cam, that is a ramp designed to work with roller lifters. A flat tappet cam will ruin roller lifters in short order as a flat tappet cam is ground as to rotate the lifters to equalize wear. Now, since the main benefit to a roller cam is the aggressive ramp profile it allows you to run, you need to determine if your engine can make use of this benefit. To realize this, you are probably at minimum looking at lightweight, oversize valve train, lots of porting, and carb/exhaust improvements. Lots of additional cost just for a roller lifter! Mark
EA71 wont stay running
+1 on the switch. Take a look at the back. They sometimes work loose from the lock cylinder. Mark -
make your 360 unsiezeable
Datsunrides replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
2 stroke seizures are usually either by too tight a piston to cylinder clearance, or running lean, which is basically overheating. The most likely cause of the cylinder clearance is a piston expanding more than normal. Wiesco's had this issue years ago. I can't remember how many seisures I had on my old RD400 due to this. Couple extra thousandths on the hone did the trick. Made the motor a little noisy when dead cold, but no more seizures. I don't think the coating will help with the issue, but maybe it will. Those are more for lessening friction. Best bet may be a little more piston/cylinder clearance and possibly jet the carb up a notch to keep it cooler. Maybe run a little premix to help out? I am not a 360 guy, more just giving my 2c based on years of playing with street 2 stroke motorcycles. Mark -
Any NZers looking for wheels?
Datsunrides replied to Ross's topic in Historic Subaru Forum: 50's thru 70's
Nice wheels. Mark -
EA71 Out of Round main bearing supports
Datsunrides replied to howpow's topic in Historic Subaru Forum: 50's thru 70's
May be better to upgrade to an EJ. Mark -
So Florida cold = what 70 degrees? Actually, while carb icing is more prevalent in closer to freezing temps, it can happen in somewhat warmer weather just due to the velocity of the air flow thru the carb venturi. Probably not your issue though. I would think if is was a fuel pump issue, it would take a few seconds to restart due to the pump having to refill the carb. May be as simple as plugged main jets, which a good carb overhaul would fix. Mark
Not really. Unless you tear down the engine, you will usually find out about a bent rod by catastrophic failure, either by the rod physically breaking or a piston/wristpin letting go due to excessive side loading because of the bent rod. Neither situation is pleasant. Mark
If it's stalling while accelerating, I doubt it's the accelerator pump. That only comes into play as you first hit the gas. Could be a failing fuel pump. If you could cut in a pressure gauge and tape it to the windshield while driving would sort that in short order. Another thought, based on the cold weather comment would be carb icing. Do you have the hot air tube to the air cleaner hooked up? If so, is the flapper working? Mark
If you end up needing some parts, give me a holler. I have some stuff from a parts car I dismantled. Mark
Probably just years and years of the engine expanding and contracting. Well, if it hydrolocked while cranking, you *probably* are OK. If it was running and it did that, expect some bent con rods, to some extent, at the minimum. Water is nasty in that it does not compress, so that force has to go somewhere. Mark
I would agree that it would be better to get a good replacement engine than try and save the old one. Probably cheaper too. I would think the traditional method of line boring would create a whole lot of other issues, like line boring the cam supports also, possibly having to shorten the pushrods, etc. I believe you can get oversized (thicker) bearing shells, that are meant to be used in a bored out (not line bored, two different things) block. Again, I would just go with a new motor. I still see old stock rebuilt EA71's popping up now and again for less than $500, sometimes much less. Mark -
Wow. Another coupe pops up. Keep us updated on the progress. Mark
