suberdave
    3
Everything posted by suberdave
  1. lets show some more old school love!!! even if you dont Dyno your car, come down and watch, its lots of fun. -=Suberdave=- http://www.suberdave.com
  2. Ill be there around noon saturday... and ill be ready to throw down!!! should be a blast, i went last time an it was awesome... -=Suberdave=- http://www.suberdave.com
  3. i have thought of that before. here is a photoshop that i did for fun. yeah i thought of using coupe doors also, but moving the B piller would be a real PITA. but using stock front doors and just molding in the rear, wouldnt look as good. link to my thread http://www.ultimatesubaru.org/forum/showthread.php?t=76831 -=Suberdave=- http://www.suberdave.com
  4. Rad fan. take the A/C condensor out and throw it away. now you have room for the elec. fan in front of the rad. -=Suberdave=- http://www.suberdave.com
  5. can it be done... yes. there are adjustments in the rear. however it is not easy at all. i have spent hours working on it. and most alignment shops will not spend much time on it, before they tell you it is not adjustable. if something is wareing, than something is probably bent. -=Suberdave=- www.suberdave.com
  6. as far as i know. all the GL's 89 and older had that emblem. then in 90 when the Loyal came out they switched to the new style emblem more like the ones you see on todays subarus. the logo at the top of the USMB page is a combnation of the two. notice how it has 7 stars. however all subaru emblems should only have 6. -=Suberdave=- http://www.suberdave.com
  7. i agree, and i have a printed copy of that manual. my only questine is "why are they red" other than that they look good... good image to have... -=Suberdave=- http://www.suberdave.com
  8. yeah i run octane booster. looks like that may be the cause of my problem... should it worrie me that this one is worse than all the rest? they are all red but this one is just a little worse... -=Suberdave=- http://www.suberdave.com
  9. i know a good plug should be kinda brownish, but these plugs are more of a red. these came out of my EJ20G swaped wagon... they have about 5K on them, what do you think? -=Suberdave=- www.suberdave.com
  10. well i can tell you that the Chevy and Saturn cars with EPS dont use any fluid. the system is 100% electric. just uses a motor. no fluid at all.... -=Suberdave=- http://www.suberdave.com
  11. yeah it has worked since shortly after i installed the struts. is it worth it... for cool factor... yes. for funtionaly... probably not. with the EDFC motor in the rear my car is as low as it will go. if i took it out i could drop it down a bit more. and i think it would look a bit better. if you think it is going to be a problem. i would not get it. you can still adjust your struts. you will just have to get out of the car to do it... -=Suberdave=- http://www.suberdave.com
  12. i just went to the local hardware store and looked through a bunch of bushings. and they had some... i think i paid like $1.25 ea. for them -=Suberdave=- http://www.suberdave.com
  13. here is the link... http://www.ultimatesubaru.org/forum/showthread.php?t=65917 these are in my 88 GL Wagon also with a EJ20G. they are about the best setup you can put on a EA82. a bit stiff for daily driving but awesome for spirited driving... -=Suberdave=- www.suberdave.com
  14. As far as Bosch plugs. i wouldn't put them in anything but a VW or a lawn mower. i am auto tech. and i have seen Bosch plugs cause random misfires in many different kinds of cars. i would toss them and get some NGK's, also get a good dist. cap and rotor. and some good (again NGK) plug wires, and a new O2 sensor. change the oil and run some good fuel system cleaner through it. and fix the exhaust leak. and i would bet that it will pass SMOG. if the car runns and drives it "DOSE NOT" need a rebuild... i wouldn't even wast my time doing a compression test on it. if it has low comp. in one cyl. you would feel it, it would have a slight misfire... -=Suberdave=- www.suberdave.com
  15. this has happeded to me a few times... its not all that hard to fix. pull the front grill off. by poping the two pins that hold it on and you can get it off without popping the hood. now reach behind the latch and find where the cable attaches. pull it. now your hood is open. now tape the end of your "new" cable to the back end of the old cable in the car. (you will have to cut the old cable so it no longer has the mounting hardware on it) this way all you will have to do is pull the old cable out and it will pull the new cable into place... and just like that its all done... -=Suberdave=- http://www.suberdave.com
  16. well first off i think i installed the first big brake kit on an EA car ever... its a Wilwood kit that was made for a 02-05 WRX... it uses a 294mm Rotor and a 4 piston caliper... and my new battery hold down... before the battery was mounted sidways, it says right on the battery that it is unspillable. but it leaked out the vent when i was placed on its side. so i changed it. it dosent leak anymore... Oyeah i also mounted my new Cusco oil cetch can that i won at WCSS9. -=Suberdave=- www.suberdave.com
  17. next year you should go around Navada. go south on I5 all the way and hang a left in to Arazona... you guys and Navada dont seam to get along all that well... let us all know when you get home... -=Suberdave=- http://www.suberdave.com
  18. Awesome to see you made it home... now just hope the AZ guys and gal make it home as you did. -=Suberdave=- http://www.suberdave.com
  19. no way, thats the same size as a RX coupe door. and ive parked in many pull in parking spots with them... i would never cut up this wagon. im not a body man and im sure i could never do something like this on a real car anyhow... -=Suberdave=- http://www.suberdave.com
  20. a two door wagon... -=Suberdave=- http://www.suberdave.com
  21. they are still uplaoding should be done by 9:00 (sunday) -=Suberdave=- www.suberdave.com Edit: they are all uploaded...
  22. if i have something you like Email me what the picture name is and ill email them to you... email is david (at) suberdave dot com sorry i got mostly oldschool but some new gen also... http://photos.suberdave.com/viewer.php?albid=19&stage=2 -=Suberdave=- www.suberdave.com
  23. looks good... -=Suberdave=- http://www.suberdave.com
