suberdave
    2
Everything posted by suberdave
  1. when i did my rear R160 converson into my GL wagon, i got some converson races from http://www.rockfordcv.com/rcv.htm . they were only $6 ea and worked to mate the WRX inner to the GL shaft with no problem. i know its different but if all else fails its another path to follow. -=Suberdave=- http://www.suberdave.com
  2. this is what i did for my CAI. More Pics http://www.suberdave.com/subaru/intake/intake.htm -=Suberdave=- http://www.suberdave.com
  3. i have not done it in a legacy. but what i will tell you is, it will fit. pretty much any engine will fit in the car. you will just have to make the wiring and stuff work. if you have the time and some know how. go for it... -=Suberdave=-
  4. if you need any EA82 parts, just let me know. i have whatever you need. i think... its a little bit of a drive up to seattle, but i will make it worth the trip. i have: EA82t' long blocks wireing harness' ECU's spider intakes FTAWD D/R w/ Diff lock Turbos Turbo back Exhaust enough parts to do a swap fore sure. -=Suberdave=-
  5. i was wondering the same thing. i have almost the same setup. the only reason i haven't is cuz the EA master cylinder seems to work just fine. -=Suberdave=- http://www.suberdave.com
  6. dont pull the dash... whatever you do... way to much work... i just pulled the steering collum. thus gaining axcess to the underdash aria. -=Suberdave=- http://www.suberdave.com
  7. according to what these guys say http://www.type-ra.co.uk/my93specs.htm the injector dose nothing... i have also herd that it is for idle enrichment. but i dont know why it would need it. no other EJ20G has it. and last i have herd that if you buy the $400 group N rally chip it then puts it to use. but we will see, once it gets running this summer. ill keep everyone posted. -=Suberdave=- http://www.suberdave.com
  8. Cats what are those??? i thought everyone ran stright pipe now a days... -=Suberdave=-
  9. from what i have read, it dosnt realy do anything. but it looks cool. and may have potential for something... -=Suberdave=- http://www.suberdave.com
  10. i would say, they keep finding me. wasnt really looking for another EJ20G, it just kinda fell into my lap... -=Suberdave=-
  11. my $0.02 check your yellow power wire at pin 2 into the coil pack when cranking. sounds like maybe you have acc power there so it has power in all positions but crank. thus a little pop when first cranking or right after cranking... this pin should have B+ power. so it has power in all key positions. if thats not it try checking grounds the ignitor has a common ground with ECU pins a11 and a22. dont just use an ohm meter. do a voltage drop across the ground, find out how good of a ground you have. hope this helps... if it dosnt let me know and ill look at the schmatics when i have more time. -=Suberdave=- www.suberdave.com
  12. yeah both front struts are bent. the good struts from this car were swaped out for these bent ones off of a lifted subaru that was jumped... -=Suberdave=- http://www.suberdave.com
  13. i may have to bring more than one car... -=Suberdave=- http://www.suberdave.com
  14. some before pics of my new swap... the car... 1987 Turbo Coupe. CA car = no rust. needs new hood. have new grill... the engine: 1993 WRX RA... need i say more? 5th injector for more pics check out my websight... http://www.suberdave.com/subaru/RX-RA/ extras: full body kit. panted black... XT6 suspension and hubs front and rear... 17" wheels... 205/40/17 tires... Xt6 sways front and rear... I think ill call her REX-RAY -=Suberdave=- www.suberdave.com
  15. if you are going to be off roading id go with the D/R -=Suberdave=- http://www.suberdave.com
  16. there is a huge difference in weight between the turbo pully and an N/A pully. the N/A pully is about 1/4 the weight of the turbo pully. eather will work. but i would guess the N/A one would be better... -=Suberdave=- http://www.suberdave.com
  17. i snaped one off. deep inside the rad. i just took a torch and heeted up a screwdriver and melted it into the plastic of the petcock. then unscrewed it like it was nothing... if you need a new one. i have bought a few from performance radiator. fare price and good service. if you just need one to get you buy. i have one you could talk me out of pretty cheep. im about 30 mins SE of Seattle. -=Suberdave=-
  18. on the EA-82 the distribuiter is ECU controled. and is more of a cam sensor than anything... look around, see if you can retrofit points into something to make it work... -=Suberdave=- http://www.suberdave.com
  19. what do you mean? you want a stock ECU to plug in and make it work? if so we need more info. any EA-82 ECU will not fit in any car. look for numbers on your ECU. i have one from an 88 GL-10 $20 + shipping if you are looking for aftermarket P&P ECU i dont think there is one... -=Suberdave=- http://www.suberdave.com
  20. here are some pics of what i did to make the rad. fit in my car... -=Suberdave=- http://www.suberdave.com
  21. cooling: you can make the legacy radiator fit. takes a bit of triming but it works well Power steering: i beleave it will bolt right up. i know the NA 2.2 dose. if not, it only cost me $20 to have custom hoses made for my EJ20G conversion. A/C will not be so easy but who needs AC... pics of my radiator @ http://www.suberdave.com -=Suberdave=- http://www.suberdave.com
  22. HA... been there done that. but mine came home on a hook. good thing for AAA. -=Suberdave=- http://www.suberdave.com
  23. that sucks. i hope you can find out whats wrong. remember to check your basics... -=Suberdave=-
  24. much easier than you think. i did a 96 JDM EJ20G in my 88 GL10 wagon. took 2 weeks. the engine drops right in (as long as you have a turbo X-member) the trany bolts right up if you use the front and rear X-member peaces from an XT6 and the center peace from a WRX. the drive shaft has to be shortened 55MM. the rear diff bolts right up (my 4.111:1 R160 LSD) the rear axels you have to buy adapters to mount the EJ inners to the EA axles, cost $6 each from rockford CV. the front EJ axels bolt right up. (if you use EJ front knuckles) i used the WRX front struts, knuckles, hubs, barrings, rotors, tie rod ends and calapers (stock 2pot). XT6 lower control arms. the EJ radeator fits with some triming. the shift linkage must be shortend. then use rear hubs, roters, calapers and backing plates from an XT6, this way you have 5X100 in the rear also. 17X7 wheels fit nicely with an offset of 40-42 and 205/40R17 tires (the spedo is even right on with 4.111:1 gears) the wiring takes the longest. but if you have a good diagram its not a problem. just remember "do it once, do it right" i think i got everything. but im sure i for got something. if you need to know more, post or PM... check out my websight for more pics. sorry no write-up yet... http://www.suberdave.com -=Suberdave=- http://www.suberdave.com
  25. just get off the fince. get your but in gear. and build that car. i know at one time you had one hell of an EA82t. but since that blew up, it seams you have been all talk and no action. lets see some action, we all know you can do it. my $0.02, go EJ -=Suberdave=- http://www.suberdave.com
