2
Everything posted by suberdave
any EJ will bolt right into an EA82 body car, you just have to use a turbo crossmember if you are using a turbo engine. the trans is a little harder. if you can find an XT6 trans corssmember it will bolt right up, or you have to do a little modification on the impreza crossmember. if you use the EJ trans (witch you should) you will have to have the driveline shortened. side note. i see you live in Utah, where abouts do you live. im in Utah once or twice every year...
i just used the engine harness. no reason to redo the dash. the trans will not matter. mainly because is sounds like to me like you will no be using the stock trany anyhow... what you have listed is a good start, engine/trans/engine harness/and ecu.
