Fordman
Location
south of kc
Vehicles
I Love My Subaru
Fordman's Achievements
Advanced Member (3/11)
0
well the parts store chains dont sell the pulley now do they? and that was the part i was wanting and i though he was offering to me. because I COULD NOT get the bearign out or off no way no how. pulling the snap ring was the only way. if i ever offered soemone somethign for sale i would follow through by sending a pm as well as a messeage in any forum that i posted about. mature. is responsiblity to follow through. not tease someone now is it. what else is mature is to want to want to reply like that. and make a situation even harder to get anything. by the way forget anyone on here ever helping me agian F that. dont bother repling i will not be back.
well i have been watcvhing thisd thread and my pm and email fo rinfo that i asked about buyign that from you. and you are the slowest mf out there. i posted in the spring that i wanted and needed this. i have not been able to get mine apart no matter what anyone says. i had been running is sounding liek crap well now it is ttrashed. thank yo uvery much fo rnever replying and dont ever offer me anything for sale again acer.
well no isuzus at the junkyard either. it was gone. i did try to knock the bearing out and i had no luck. i think i need a press to get it out. that was why i took it apart was to jsut replace the bearing. but i am not sure it will come out now after i had a look at it. but it might. next tiem im at the shop and have tiem i will put it in a press and see what happens.
well i called the dealer for a new one. and i didnt liek the price at all. but i am stuck unless i want to go without air. so i took the bracket off and took the snap ring off the pulley. i tore the cage out fo it. since it was what was jambing the bearings up. i packed heavy grease into the bearing and races. i put it all back together. it turns but makes a slight noise now and then. this rig probably wont last two days. but i did try it. it may work until i get a new pulleys from some place. do yuo think isuzu will have a similar idler pulley on it? a trooper or similar model that looks like a trooper?
93 subby legacy 2.2 with a/c. the belt burned off of it i think. anyway so i replaced the belt today. started the car and let it run. witht he a/c on and off. the a/c belt idler pully wasnt turning. i'm sure that it should. can anyone confirm that it is supposed to turn and i just didnt over tighten the bolt. i took the botl loose and ran it again and the pulley still didnt turn. so if it is suppose to turn it doesn't. i took a bad video and a picture fo the idler.
thank you for clearing that up. i found the outer cable is broken up inside of the door track so it slides around. but that doesnt say why the inner cable is stuck. it mihgt be the outer cable goes through a third cable and that is where it is getting stuck at. i dont know. i will probably junk it unless i can find soemthing local that will work. i doubt it. but you never know what can be robbed from other cars and work.
i havent been ot the city in awhile. and i almost hate to go to the yard up there because of the prices. and i don't know if they will even have something if i drive all the way up there. i know what you mean by mud too. i was at the locla one this morning and it is muddy out there. i almost fell down because of the mud yesterday. let me see if i can fix it today. i don't know. i am thinkign i need to call the dealer and see if they will warranty it or not. i'd rather themfix it if its free. but then they would probably nit pick the rest of my riggings on the car.
no junkyards around here witha compatible seat belt in it. im sure not buying one from the dealer. is there any place i should look at partically to get it unstuck? i think it might be in the top of the door track guide behind the headrest. but it could be its just pulle dout too far and needs rewound to get unstuck?
the drivers side automatic belt retractor isnt working anymore. i was told on another forum the seat belts were warrantied for life. i dont know i believe that but many confirmed it. anyway just in case. what could be the problem? the motro does work. i unhooked the cable from it and the motor works. the gears arent stripped. it is somethign to do with the cable being bound up. when it hapened the cable came out of the track. is this a common problem? i fso where do i look to fix it? Edit: this is a 93 legacy 4 dr.
