loonysalmon
Location
Houghton, MI
Vehicles
I Love My Subaru
loonysalmon's Achievements
Member (2/11)
0
1989 XT - Transmission questions
loonysalmon replied to loonysalmon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for that gloyale. I really just had a question in regards to how to ground that pin out. I'm not at home now, but I will have my dad do that if he's feeling up to it. I'll report back to this thread as soon as I can with results. It might be next weekend. -Tom -
Okay, so john sent me http://www.endwrench.com/pdf/feb2004pdf/4EAT.pdf earlier. It says in the fsm that there is a 17 pin connector and to use pin 11 to ground to get the trouble codes to flash through the power connector. It stated through a diagram that it was on the left side of the vehicle, however I could not find a 17 pin connector on the left side of the vehicle (passenger). I did however find one on the right side of the vehicle, but it did not work as planned so I found out. Am I able to just use the FWD switch to enable the trouble codes? Thanks In Advance, -Tom PS: From the looks of it though, I'll be driving a 1989 GL back to school. Good thing it's pretty much mint, eh? -
However, that never happens and 16x flashes mean that there is a problem with the transmission. How do I go about getting the codes from the TCU? -Tom -
Gary, I just took the car for a short drive and then shut it off and restarted it. The POWER light just blinked 16x. I'm assuming that you have a simple solution. HOPEFULLY!!! :banana: -Tom -
OK, so I am getting 60mph @ 3900 RPM, definitely not standard for a 4 cylinder. Am I right to assume that O/D is not kicking in? If so, how the hell can I fix this? I've got to road the car up to School tomorrow -- two hours away and want to fix this asap. Ideas? I've been reading that the transmission needs to be at a certain temperature or something like that before it actually shifts into O/D. Also, going from 1-2 it has a hard shift...connected? Maybe Fluid is clean and not burned. -Tom
1989 XT - ECU questions
John in KY just helped me out majorly over on the SubaruXT forum. Evidently I didn't have the flat part of the steering column spline under the pinch bolt on the universal joint. Picture of how I had it setup here. No wonder why it looked like this on the inside of the firewall. Thanks again John! -
I am currently reading the FSM for the 88 XT and it says to temporarily tighten the three bolts, remove lock bolt, connect meter cable, harness, and pop-up cable, and then install the universal joint. Should I have currently removed the universal joint at this point? If the manual says so, I think I might have to. What are your thoughts on this? -Tom -
I got the column in to the universal joint fully to the line at this point, however I cannot get the bolts to line up to the dash just right. I think I need a helper that is stronger than my dad. The steering column is fully clearing the firewall hole, however it is not lining up correctly to bolt up to the dash. I'm at a loss here. Any tips/tricks? When the wheel is lowered a bit, I can get it to push through the firewall more, however when I go to lift it up, it comes back a bit. I am guessing there is a perfect point in there where this works just perfectly. My father, however, is not able to understand me when I say to push in hard and move the dash upwards. Maybe my mechanics are just bad, however I'm sure this is the problem I'm having. -Tom -
Any tips for how to get the steering column back into the universal joint easily? The spline has about 1/16-1/8" left to go and just wont' go any further. Is there a more simiple way to get this back in? The U-Joint just keeps bowing to the side or not staying still. If I could hammer it on there it'd be easy to fix it, however this is not fun at all.... Definitely no dancing bananas for this post.... -Tom -
Heater core seems to be installed correctly. Dash is installed. Time for the Steering column. I should be able to get it driving today after I get the steering column in. -Tom :banana: -
GRR, this heater core aches me while I try to reassemble the pieces and clamps... I'm just getting fed up but still happy! At least I have until wednesday before I leave for school. The more complete my car is put back together, the more space I'll have. HAS ANYBODY EVER INSTALLED AN AFTERMARKET STEREO IN AN XT? Will it mount up with a kit, if there is one available? I just got a Single DIN aftermarket stereo today on my trip back from University. Traded $50 from my computer sale for a friend's slightly used unit. -Tom -
Haha, yes! For a little bit there, a relay? was clicking on and off. It was circular and in the center of the dash area at the bottom, in front of the shifter. I heard it in the engine area as well, near one of the spark plugs on the passenger side. I was wondering what the noise was, even though it went away. Also, the lifter has since quieted. I'm heading back to my school tomorrow to sell my old computer to a good friend. Hopefully I'll get back early enough to take care of some other stuff on the car, namely putting the drive shaft back into the Universal joint. Lets just say I was trying to get the thing bolted back up and it didn't cross my mind to hook it back in on the engine side. :banana::banana::banana: :banana: Now lets bring on the Jagerbombs and brews! :drunk::drunk::drunk: :drunk: -Tom -
IT'S ALIVE!!!! Fuse #11 had a loose and/or corroded wire on it--the black/white one. I wiggled it a bit and hooked the fuel pump back up and BLAM... it was alive. Dad says lifter is a bit loud but he has something to remedy that. It's idling at about 500, a bit low if I do say so myself. I LOVE LIFE! I FEEL LIKE A LITTLE KID AGAIN! :banana::banana: YESSS! -Tom -
Thank you gloyale, I will get right on to doing that. I charged my battery overnight but it turned out that the battery was completely done for. I'm charging another battery at the moment and hopefully this one isn't toast as well. FSM's have the location of these Ig. relay, FP relay, and Purge solenoid (or just disconnect whole engine harness). I'll have to look around for them however. Thanks so far. And again John, I wasn't ignoring you -Tom -
John, I replied on subaruxt forum, my email addy is loonysalmon@gmail.com
