cl4yd0h
Everything posted by cl4yd0h
  1. Im totally stumped.. I have the plugs out and can hear compression in all cylinders when i spin the crankshaft in neutral. Its connected to everything.. and the timing belt doesnt even budge. As far as I can tell the timing belt is directly connected to the crankshaft, correct?? When I put the car in gear and move the crank shaft the timing belt moves? Am I just overlooking something stupid? I mean the timing belt should spin when cranking over engine with starter, or else how is the damn thing gonna start.. How the heck do the gears play a role in this??? Its to my understanding the timing belt directly relates to the crankshaft. correct me if im wrong..
  2. When I turn the crankshaft pulley with a socket wrench while the car is in neutral it the timing belt does not move with the crankshaft. when the car is in gear and i move the car with the socket/rock it the timing belt moves with it.. I dont understand how this is possible?
  3. Timing belt intact, worn but, not broken. Cant seem to find this main relay to power ECU though? Where abouts is it, and any other ideas?
  4. I checked all the fuses under the hood, but not the relays, I dont know how to check if those relays are good? Other then you can hear some go off when you pull them out. The indicators just say SBF-1 etc. I have no idea what SBF is. I will also check the main relay under the dash and try to find out somehow if its good or not. I will also check the Timing Belt and get back to you guys. Thanks for the help so far! (Sorry for double post, wacky internet.)
  5. I checked all the fuses under the hood, but not the relays, I dont know how to check if those relays are good? Other then you can hear some go off when you pull them out. The indicators just say SBF-1 etc. I have no idea what SBF is. I will also check the main relay under the dash and try to find out somehow if its good or not. I will also check the Timing Belt and get back to you guys. Thanks for the help so far!
  6. Hey, This is a cool place you got here, Glad I found it. Out of no where went to start up the car and would just turn over. Wouldn't fire or even pop off a couple times. Ran awesome up until then, no prior symptoms. From check engine light blinking ive managed to gather this information: 33: Vehicle Speed Sensor Circuit 11: Crank Angle Sensor or Circuit 13: Cam Position Sensor or Circuit 31: Throttle Position Sensor or Circuit Light was never on before this happened, it all happened at once when i tried to start. I Checked any fuses that correlate with anything important and I couldnt find any blown ones, even checked alot of em for continuity. Checked for spark with timing light and couldnt get anything out of all 4 cylinders. Checked the coil pack connector for voltage and couldnt really get any readings that made sense.. like .6 or .8 volts.. Im a Chevy truck guy, I really dont know how these ignition systems or coil packs really even work.. But I would assume its not firing because it doesnt know when to because of loss of readings on sensors. Is there a common wire or fuse for these sensors? These Boxer engines are a whole new world for me. Any help or suggestions would be awesome.. I lose my job if I cant get this dang thing to run. So thank you in advance, Im really in a pickle here! EDIT: Also replaced alternator 1000~ miles ago
