sario
Everything posted by sario
Nice looking clean car!
What would you recomend for a jack?
Ned goes to the beach...
sario replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks fun! -
I think i might wait until rains before i try this.
When accelerating from a stop with a semi-heavy load, like towing a trailer, there's a thumping sound, maybe from somewhere in the middle of the car. It last for only 2-3 seconds during accelerating. No noise or problems once the car is moving. It also happens with just me in the car if I floor it from a stop while making a hard turn.
The shop said that tires were coming apart at highway speeds, yes. The U-joints broke and a transmission mount broke as well. The bearings do not feel crunchy when i spin the driveline by hand. There is some play went i change direction of the drive line, maybe one or two degrees. I'm not sure I understand how different sized tires would cause this, but the vibrations went away with new tires.
I took the car to a shop for their opinion. They want to rebuild the rear diff, but I’m not convinced that’s the problem. I'm going to do some research and see if any LSD differentials from newer outback’s are a direct bolt in replacement. If they are, I'll use this an excuse to get do a bit of an upgrade.
They tire tread was separating at speed. . All the tread measure the same depth, but would actually go out of round at highway speeds. The first two that failed baffled me. I even took to a private garage that specializes in subarus, and they couldn't figure it out either. The third drive line broke at about 45 MPH, and broke the transmission mounts. I ended up having the car towed to a second garage, and they figured it for me.
I do have king springs on the car, so it sits about an 1.5" taller than normal. That might have something to do with my problem. Also I'm pretty sure the first two drive lines failed because i had tires that were having tread separation issues at speed. Do you think there is something else i should be checking for?
It would definitely save me some money, but I've tired of replacing this drive line. I've boughten four used drive lines for this car so fair. Two of the failures were actually tire related problems, but the other two were just worn out drive lines. I'm hoping these aftermarket rebuilt drive lines will be a little more robust.
