sario
Everything posted by sario
I'm working an f150. While pulling out the seal for the rear bearing i put scratch in the axle where the outside of the seal sits. Is this going to cause a problem? should i put a touch of sealant there before i tap the new seal in? Thanks
autozone calipers
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Ok i installed the autozone calipers, along with new duralast rotors. Hearing about the warranty makes me feel better about some of the negatives I've about read. The calipers in the box were rebuilt OEM's and the hardware is similar to original. I'll post back here if i ever have a problem. On a side I bought a set of pads, that i didn't up needing. The clerk told me that the pads were also lifetime warranty which includes normal wear and tear. You guys weren't kidding when you said they had a good warranty. -
autozone calipers
PS I'm 20 miles from. I've been driving 5 miles and then letting everything cool down. So I have a lot of time to over think this. -
autozone calipers
Numbchux that's good to know about cardone. Napa called me back and said they could have a set by noon. Its from Napa united, which cost more than their car done series . any options on those? -
Brake Boots
Thanks for the information. I'll replace those next oil change then. -
Easy to work on. Lots info online, and people willing to help you figure out problems, thanks USMB.
OEM PARTS online store??? Subaru Loyale parts
sario replied to 92LoyaleH4's topic in Products for your Subaru
As grossgary recently pointed out to me, opposedforces.com is a great website to find the part numbers. The online dealers catalogs can be hard to find some of the smaller parts. -
I'll give that a shot. I'm really hoping to avoid scrubbing with a toothbrush, although i admit that probably the best way.
Robots rule
sario replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Wait? Did the forester just skip the CVT and go straight to the flux capacitor? -
One hot little Subaru 360......
sario replied to 2stroketurbo's topic in Historic Subaru Forum: 50's thru 70's
that was crazy. I'd love to drive a 360, I'd REALLY like two drive one with flames shooting out! -
How does everyone clean your engine? Mine isn't too bad, but i'd like to get it cleaned up to see where any oil leaks might be.
Huh, that relay should have been just fine, even with the inrush current. Sorry for going off on a tangent. I do a lot with motors and motor controls at work, so just get curious. I really enjoy controls and control logic.
Do you still know the brand and part number of the SSR? It sounds like the SSR was overhead. Were you using a heat sink? If not, it might still be salvageable.
I'd have to agree with davebugs about staying away from oil less. Unless it's just something you use occasionally, or don't mind a lot of noise. Whats your budget? If its in the $1000 + range there are a lot of great two stage 5hp compressors out there. For my personal use i just have an Makita mac2400. It's relatively quiet,, small, and It puts out 4.2CFM at 90 psi. It keeps up with my nailers, but i do have to wait on it if i'm using impact guns sometimes. It would not keep up with blowing out an entire shop with an air wand though.
I don't think there is a definitive answer about this. On other Subaru forums many people say that peak global life time is practically the same thing as Subaru coolant. But it is an OAT coolant, and other people say that Subaru’s should never use OAT coolants. All I have is anecdotal evidence like everyone else. I have been using Peak Global life time for 90,000 miles and I haven’t destroyed my head gaskets, yet. That being said, I will switch to Subaru coolant next time. It’s $20 for a undiluted gallon. So it’s relatively inexpensive, just an inconvenient drive to the dealership
