usasail
Everything posted by usasail
  1. Hi I have an '03 Baja 2.5 and was wondering if it's possible to change the auto transmission to a manual. I think all the one's I've seen have been auto...
  2. Hi guys - Thanks again for the info. Yeh I asked my bro's and they said to clear the ECU just take off the negative terminal of the battery. I did that it cleared the "Check Engine" so no more codes available...but I think that did the trick. I'll keep my eye on it if it acts up again and if the check engine light comes up again I'll be sure to get the codes. My brother was right this is the best Subie shop in town:banana:
  3. Cool Thanks Legacy777. Yep that other Subie owner from Colorado had some multi issue's I guess. Since I've posted the check engine just came on, it's been about a week and 1/2 since issue started. My brothers think it's not the O2 sensor since it happens right away once load is established in reverse. I'll try the ECU reset, but if I could repeat Ed's question of how you might go about doing this? Thanks again, Monty
  4. Hi I just moved from Texas to Wyoming and now at 6300' in elevation. I have an 03' Baja with 116k mileage, also with all original oxygen sensors. I've started to get hesitation while engine was cold now it's starting to hesitate while warm as well. Would it just be a replacement of sensors or is there a setting somewhere to allow more oxygen in that I can adjust? Thanks for the help. Monty
