RMVR53
RMVR53 last won the day on July 12 2019
RMVR53 had the most liked content!
Gender
Not Telling
Location
Denver Metro
Interests
restoring/racing vintage/historic race cars
Ezboard Name
RMVR53
Referral
eons ago on a web/BBS search
Biography
Real Estate Appraiser, Vintage racer
Vehicles
00 Legacy Outback
Recent Profile Visitors
710 profile views
RMVR53's Achievements
USMB is life! (4/11)
16
FIXED!!! I found another post on the Outback forum from 5 years ago. Reading the post is was as if the guy was me working on my car. His final post is the same as this... one tooth off.... Both cams were on time, but the crank was 1 tooth retarded (or you could say the crank was on and both cams were one tooth advanced). Its my fault as I put a new belt on when I did the water pump 6 months ago. Why it took 5-600 miles to trigger I don't really care right now. In any case, its fixed that and WOW...runs great, no miss and I've replaced a lot of parts that I probably needed to anyway so I'm happy. Thanks to all ya'll for direction, guidance and encouragement. Bill
how about a screwy code reader. I picked up a cheap mini reader for the live readings. It gave me the last two codes. Reset it and just ran the 'test' again then read the code with my older INNOVA . Got a code...P341 Thats 3 after market CmPS and 2 Dealer Sensors. So either the reader is wrong or something is taking out or making the cam sensor fail under load.
ok...finally had time to play with this this am. Installed the CmPS last week and got no codes but problem persisted so starting from there. I had read on an Outback forum that another poster had a similar issue and he swapped out the upstream O2 sensor and the problem went away. So I installed a Bosch upstream O2 sensor. Still doing the same thing so I kept driving it till it thru a code. P0203 and P0103 - MAF sensor high reading and same for #3 injection circuit. Well, as best I remember a 2000 Subie doesn't have a MAF. Thoughts? hey....a least it didn't throw a CmPS sensor code!!! BIll oh...and this time I watched - the tach does "flinch" when it stunbles
