mountainchef
Location
Black Diamond
Interests
Snow sports, water sports(kayaking, wakeboarding), backpacking, alpine fishing, mountaineering, general outdoors stuff. Gardening and landscaping. Food, alcohol and social functions.
Occupation
Student
Biography
Former chef of award winning barbecue restaurant. Third generation gear head. Cheif "home" mechanic. Auto and motorcycle enthusiast. Head gardener and landscape artist for the homestead.
Vehicles
1992 Legacy L wagon
mountainchef's Achievements
Member (2/11)
0
You said you replaced the WP when rebuilding engine. I have had issues with refurb'ed WPs, and recently had one fail right after the warranty expired. I decided to run "new" WPs from now on. The symptoms I had were similar to what you're expressing. I did my WP and coolant temp sensor; no more issues.
I recently went through the similar problems in my 92 Legacy wgn. Based on the symptoms you described I suspect your water pump is bad. Before you get too carried away, read your trouble codes to figure out what the car is trying to tell you. Mechanically speaking, you're going to do some fairly routine Subie stuff. Get a new, not reman'd, WP from NAPA or from the Subaru dealer, a "Subaru" thermostat, and a full timing belt and idler pulley kit. I also had a leak from the thermostat housing because of corrosion and pitting. If you discover this as well, buy a new housing from the dealer. When it comes to parts for Subaru engines, don't skimp, buy the good stuff; preferably Subaru brand parts when you can.
A while back I had a local shop install a low-mile transaxle in my 92 Legacy L wgn. There was a small hangup with availability of a trans with the same gear ratio (3.9X stock?) so we decided to install a 4.11 and matching rear axle. After a little reading, I began wondering if I had inadvertantly upgraded into an LSD. That said, my questions are as follows: Does anyone know how to indetify, by serial number, what is now in my car? If the current set is VLSD, do I need to used any special fluids when servicing?
I agree with the general understanding that seals, gaskets, and ignition parts should all comes from the dealership. Don't waste your time trying to save a few bucks on these parts. You will likely regret it. Timing component kits from RockAuto.com have treated my brother and I quite well over the years in our Subies. One of their kits also includes a water pump for about $250.
Visually things look pretty good but it's hard to determine if something is only slightly out of kilter without comparing to a known good part. Had this issue rebuilding the front end on my mom's Exploder. Already planning to do tie rod ends. Driver's side has a split boot and is oozing. Struts are in the near future but I need to rebuild the rear brakes first. Trying to buy all the parts for the suspension and do it all in a weekend so I only pay for one alignment.
Low speed, maybe 10-15 mph. Impacted slightly buried curb in a mostly forward travel with a slight passenger side drift. Probably about a 5-10 degree angle to the curb. Car now has light to moderate pull to the right. Could I be looking at a bent control arm? I don't have anything to compare parts to so it makes diagnosis a little challenging. Looking for a little direction from some of the more knowledgeable. Thanks for the support guys.
Just got done with this on my 92 leg wagon. Thoroughly cleaned all contacts on master switch, re-assembled and tested; all is well in the switch. The motor is a different story. There is a worm gear to ring gear drive. Worm gear is metal and ring is plastic. Worm gear should have an adjustment for gear mesh. A screw with a jam nut covered in hard glue at the top end of the motor. Provided that your plastic ring gear is not too worn you may be able to adjust and fix this problem. If so, I agree with "sam888". Clean and lube every aspect of window function. However, I would use an aerosol based teflon spray lube if available, less messy and longer lasting. Good luck!
